EGT and NOX Sensor...KISS IT PLEASE
Too bad you gave away your last pipe. I bet a fabricator could have helped you out with a bung in that pipe. My bet is that the aftermarket will soon have a new part number for post DPF pipes that includes this accommodation. Sux we now have another sensor to deal with.
For the most part, I keep my windows up and stereo on, so I've never heard the blow dryer or pissed off cat I've heard people mention before. I guess if I had, I would be looking to ditch it too. Good luck!
The pissed off cat sound really is only an issue when there is a trailer attached. The sound is directed forward and we tow trailers all the time. Not a big deal but it's nice to get rid of.
Thanks to the OP for starting this thread...... I just picked up a '15 and trying to sift through some of the other threads on this topic will give you a damn head ache and a bad case of cross eye!
This is very simple and easy to follow...... I got 400 miles on my truck..... In the next weekend or two I plan to take out the 4 sensors and put on some anti- seize. I will also pick up 2 spare sensors.
I see that in Smoky diesels post he Aldo list the NOX sensor........ I assume this failed also and shuts the truck down? If so I guess I need to get one also. Fortunately I have a friend that works at the dealer so I should be able to get an employee discount.
I am now looking into buying a simple code reader or possibly the Edge CTS which is a code reader but also displays a ton of info that Ford does not give you.
If you use PermaTex silver anti-seize, it won't. If you use anything with bronze or copper in it, it will get rock hard on exhaust temps.
From an old 6.0 guy.
NOx recall
I have a 2011 F-250 6.7 Diesel. My engine light came on and the dealer tells me it is not under warranty or recall. Price is $504.00 to replace. I don't like the "Replace or engine will shut down" threat. Isn't that extortion?
Does anyone have a copy of the actual recall notice? When I did a search on my VIN on Ford's website it shows no recall notices. I would like to go in with some ammunition to save me a few bucks.
Thanks in advance for any help.
Is this what you are looking for (click link, read thread)
https://www.ford-trucks.com/forums/1...t-sensors.html
Here is another read you may find worth your time to read
https://www.ford-trucks.com/forums/1...-7l-14e03.html
Sorry, I was in too much of a rush to get this posted. I am told it is the NOx sensor. 70,332.5 miles. I don't know the error code only that the engine light came on over the weekend and my wife needs to do some towing this week. So in it went to the dealer and they came back with that price. I am also not sure if the price includes labor.
#28
Gotcha. I'd encourage you to read those threads and then talk to the dealership to see what exactly they are replacing. Considering the customer satisfaction letter is out and you are under the stipulations set by FoMoCo, I'm not certain how they can charge you? Have you called FoMoCo customer service?
800.392.FORD
I'd tell you to PM Crystal (the Ford rep here), but until you have some more posts and time here, you don't have messaging capabilities from FTE. Welcome to the site
800.392.FORD
#29
I do love the way you posted it and questioned it as a matter of "Extortion" however. And as much as it brought me a smile and a laugh, it's not extortion. It's a FACT!!!! Brought to you by the little gremlins who manage the emissions in joint command of the CPU electrical program and roadside assistance.
Good Luck on the fix. And notice that this is most always an extension of Murphy's Law as to the timing.
#30
Crystal
