The $500 F250
#451
#452
#456
#457
This is what I use in my car. I made it all by following the Grabbs Racing videos linked below.
I did not buy the kit below. I pieced it myself from Adafruit.com site:
I also got the mouseberry circuit to turn on and turn off the pi with the cars key is turned on.
Adafruit.com
https://www.adafruit.com/category/105
PiDash Kit sold here:
it utilizes GPS for MPH to show on the dash
https://pidashs.com/
Mousberry circuit for cars
https://mausberry-circuits.myshopify...upply-switch-1
PI Dash Setup: Part 1 Overview and Hardware
PI Dash Setup: Part 2 NOOBS Install and Basic Config
PI Dash Setup: Part 3 Setup TunerStudio and AutoStart
Adafruit.com
#459
should still work as long as the MS software is some what newer.
and it all costs less than a 100.00
https://tunerstudiodashboards.com/
Custom dash from a Lambo
#460
Started wiring stuff up yesterday. I quickly realized that I should have done this back when the front clip was off. I need longer arms because it's hard to reach back in there! I am going to pull the Ford fuse/relay box back out so I can splice into it for ECU power, fuel pump power and injector power. It is a mess right now, but should look nice once loomed.
In case you are wondering, the HEI distributor and 24lb injectors are not going to stay!
#461
#462
#464
