how much lift
how much lift
just bought a 1990 f150 XLT Lariat 4X4 with the straight 6. id like to level my truck out and also run a little bigger tire. i was thnking of something in the 2&1/2 inch lift range. is there a kit that will lift my truck and level it at the same time. i dont want a 2&1/2 inch lift and end up with the front still lower than the back. also what size tire can i except to run with a small lift. how do i re-calibrate the speedometer and how will it affect performance. thanks in advance.
how much lift
You can just buy a leveling kit that will raise the front 1 1/2" to 2" and even it up with the back. They don't do anything to the back. You should be able to run 32X11.50's without any problem, 33X12.50's might rub a little on the radius arms. To adjust the speedo, you need to replace the little plastic gear on the end of the speedo cable that goes into the t-case.
"Top Fuel" Bender
10-23-2010 12:55 AM
