Power steering on stock frame 53 F100?
Old 12-08-2013, 08:11 PM
kcode's Avatar
kcode
kcode is offline
I know you can put disc brakes on a stock frame, but can you put power steering? This is on a 53 F100
Old 12-08-2013, 08:23 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Ford has a power assist unit and there is also the option of going with a Toyota PS setup.
Old 12-08-2013, 08:32 PM
kcode's Avatar
kcode
kcode is offline
The reason I am asking, is my wife wants the truck to be easy to drive. What Toyota system works?
Old 12-08-2013, 08:40 PM
CharlieLed's Avatar
CharlieLed
Midfifty 2012 catalog page 167. The Toyota PS box you need comes out of an early 80s 4x4 truck.
Old 12-08-2013, 08:41 PM
Harrier's Avatar
Harrier
Harrier is online now
You can buy a setup from mid fifty: Complete Toyota Power Steering Conversion Box, 1953-56 - Ford F-100 Parts (That's not the only option they have, some has more stuff, some less) Check out the instructions they have.
Here is a good thread on used toyota vs the midfifty (ccp company built) steering box.
https://www.ford-trucks.com/forums/1...vs-toyota.html
Here is a great thread with lots of articles. Starting on post #15 is a toyota steering swap article. https://www.ford-trucks.com/forums/6...-articles.html
Old 12-08-2013, 08:46 PM
kcode's Avatar
kcode
kcode is offline
Thanks for the links, I will read up on it! My goal is to keep the truck with the original flathead V8, but upgrade the brakes and steering.
Old 12-08-2013, 09:30 PM
kcode's Avatar
kcode
kcode is offline
Can the power steering pump be hooked up to a flathead V8?
Old 12-09-2013, 08:06 AM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
Yes, I do some work now and then on a friends 53 with a flat v8 and it has the toyo box with power steering. I cant recall what pump was used or mounting brackets.
I will say that after driving the truck it is a real pleasure. Steers so easy you'd think the front wheels were off the ground, kinda like the 60s Mopars real easy to turn
Old 12-09-2013, 12:26 PM
kcode's Avatar
kcode
kcode is offline
I was thinking about using a 60's mustang pump when I do it?
Old 12-09-2013, 02:55 PM
53OlderThanMe's Avatar
53OlderThanMe
53OlderThanMe is offline
Its easy enough to do, you may have to fab a bracket to mount the power steering pump.
Photos of my 53 PS conversion here: Power Steering
Power brake conversion here: Brakes and Brakes Plumbing
Old 12-09-2013, 03:11 PM
kcode's Avatar
kcode
kcode is offline
Thanks for the links! I will have some questions about the steering column I'm sure.
BSmart2
07-19-2019 08:30 PM
vze2c2gb
01-14-2017 08:53 AM
csuttle
04-16-2004 03:09 PM
22mill
05-23-2002 06:50 AM
ions664x4
Offroad & 4x4
05-20-2002 10:33 AM
Quick Reply: Power steering on stock frame 53 F100?
