06 F250 with 5.4 new maf and now no power.
Old 12-26-2013, 05:18 PM
jkinghorn6.0's Avatar
jkinghorn6.0
jkinghorn6.0 is offline
I just replaced my mass air flow sensor due to it being faulty (it would stall sometimes when shifting from drive to reverse) now I have no power after 1/4 throttle. It just seems to fall on its face. Should I disconnect the battery to reset the computer? I am not getting any codes now.
Old 12-26-2013, 07:52 PM
jkinghorn6.0
I am trying to figure out what would cause the loss of power when I throttle up above 1/2 throttle. My fuel pressure runs between 39 and 40 psi at the rails. And at idle maf is around 45 to 50. I'm really unhappy with the 5.4.
Old 12-27-2013, 10:57 AM
jkinghorn6.0
I disconnected the battery to reset the computer then I took it for a drive. Still running the same so I just checked my IAT and it says 212 f I also checked for vacuum leaks and didn't find any in the lines. I'm going to clean the maf and see if I have an intake leak. My computer has not shown any misses and I still don't have any codes but it will stall if I rev the engine to 2500 rpm in park. can someone help please. I am moving in a couple of months from New Jersey to Colorado and I will be towing a trailer and this truck must run well I can't afford any breakdowns on the way.
Old 12-28-2013, 08:15 AM
jkinghorn6.0
Now I have thrown a code. PM 17 and a pending for the other bank. New mass air flow sensor also cleaned it to make sure new air filter and I didn't find any vacuum leaks. Will check again tho. Any suggestions?
jkinghorn6.0
Sorry code p0174
deep101
Modular V8 (4.6L, 5.4L)
02-16-2015 05:52 AM
Mustang6147
03-02-2014 07:46 PM
Fox
15
07-09-2010 04:43 AM
redwolf4k
1983 - 2012 Ranger & B-Series
05-15-2009 05:02 PM
NDL
07-15-2007 09:21 PM
Quick Reply: 06 F250 with 5.4 new maf and now no power.
