Oil in Fuel Filter Housing
Old 12-07-2013, 12:06 AM
Al's F-350 4X4's Avatar
Al's F-350 4X4
Al's F-350 4X4 is offline
I have oil in my fuel filter housing. Any tips on how oil could be getting in the fuel system? I removed the filter and it was all oil..
Old 12-07-2013, 01:15 AM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
I bet you need injector o rings. You can get them at riffraffdiesel.com. Welcome to fte!
Old 12-07-2013, 02:58 AM
Talyn's Avatar
Talyn
Talyn is offline
Oil in fuel is injector o-rings.
Good one gabe.
Old 12-07-2013, 06:53 PM
stainlessstroker95
I try to help some times william.
Old 12-08-2013, 04:50 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
x2^^ And welcome to FTE!
Old 12-08-2013, 02:08 PM
duggyb's Avatar
duggyb
duggyb is offline
o rings are not to bad to do. just did them on my truck. might as well test the glowplugs while you are in there or just replace all of them if you dont mind the cost also inspect your valve cover gaskets and harnesses for burnt pins.
Old 12-08-2013, 05:28 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Depending on the miles on the engine, i would consider REPLACING the injectors. Their life expectancy is 150-200k
Old 12-08-2013, 09:52 PM
duggyb's Avatar
duggyb
duggyb is offline
yes very true. pop the valve covers and see what they are you might be surprised.
mine had 6 of 8 replaced with the Newer Alliant injectors.
You could also send them away to have them looked at and rebuilt/tested
Old 12-09-2013, 05:27 PM
Al's F-350 4X4
Thanks to everyone for your help, I was not sure if there was another way for oil to get into the fuel system. I have pulled the injectors and flushing out the fuel galleys and reassembling.I will update all with the out come. Thanks again for the help..
Old 12-09-2013, 05:30 PM
Al's F-350 4X4
I replaced the injectors and glow plugs about a year ago and the truck ran better then it ever has. So i'm hoping it is just the o-rings.
MONAVIERONJON
07-20-2014 06:05 PM
daddykitty
03-01-2013 06:27 PM
bismic
11-12-2012 07:55 AM
mustang_gt_350
05-23-2007 04:21 PM
Quick Reply: Oil in Fuel Filter Housing
