Ignition sticking
Old Dec 9, 2013 | 12:11 PM
ligito's Avatar
ligito
I squirted WD40 in my lock, yesterday and it works at 22 degrees.
Old Dec 9, 2013 | 12:27 PM
Gary Lewis's Avatar
Gary Lewis
I don't know the answer to that question. In fact, I suspect it varies from truck to truck. However, it is my impression from what I've read that the WD40 was squirted into the lock via the key slot, so that suggests the stiffness was dried grease in the tumbler itself.
Old Dec 9, 2013 | 07:59 PM
Franklin2's Avatar
Franklin2
You obviously can do a better job if you take some of the column apart to lube it. But I have just squirted it into the key slot, and kept working it back and forth. What was I lubing I am not sure, but I pretty much was drowning it a little bit at a time, wiping the drips up with a rag underneath the column.
And yes we have had this discussion before, wd40 is not a very good lubricant, but it is a good solvent/very thin lubricant, and it seems to loosen up and rejuvenate the old grease in the column. All I know is it seems to be a quick fix when the thing starts acting up.
fuelsmoke1
Jun 19, 2023 12:05 PM
edf250
Sep 17, 2010 07:31 AM
truckhound
Aug 27, 2010 12:43 PM
wildjon300ci
Apr 1, 2003 07:06 PM
Ryan50hrl
Jul 11, 2002 10:57 PM
