No Power to Fuel Pumps! - Ford Truck Enthusiasts Forums
Old 12-05-2013, 02:53 PM
LongE
LongE is offline
LongE is starting off with a positive reputation.
Hey guys, I have a 1988 F250, and have been trying to diagnose the issue for the last two days, have been reading hundreds of different forum posts, and I'm stumped. The truck isn't starting, cranks but its not getting fuel. When I turn the key the pumps aren't priming. I grounded the fuel pump pin on the self test and the pumps turn on. My inertia switch is not tripped, and I replaced the relay. Since the pumps power on when I ground the fuel pump pin what could it possibly be??? The EEC? Is that the only possibilty? please Help!! I really can't afford to pay an guy 100 an hour to diag it. Thanks!
Old 12-05-2013, 05:10 PM
LongE
LongE is offline
cont.
Also, I checked the fusible links to the starter solenoid and had power on every one with the key in run. Checked all the fuses. I removed the fuel line before and after the high pressure pump, and get no flow at all. The filter was replaced recently. From what I understand the power comes from the starter solenoid, and eec to the relay? Relay to the inertia switch and pumps? Like I said, I grounded the self test and the pumps kicked on...I will solve the problem if it kills me! Haha, I just want to know if changing the EEC would be the next best step.
Old 12-05-2013, 06:03 PM
et_miller_87's Avatar
et_miller_87
et_miller_87 is offline
et_miller_87 is starting off with a positive reputation.
If you've got a service manual such as a chiltons or a Haynes, id start by tracing the circuitry and checking wires first, and then components down the line from the relay. Chances are its not the eec. . by spending 20 minutes reading wires out, you could save up to 200 bucks by simply repairing a wire versus throwing an eec at it.
Old 12-05-2013, 08:51 PM
DennisMenace
DennisMenace is offline
DennisMenace is starting off with a positive reputation.
Do you have any CEL codes?
Old 12-05-2013, 11:49 PM
LongE
LongE is offline
I appreciate the replies, there is no check engine light on. I'm going to check the wires over again to see if I missed anything. There was no obvious damage in the wiring that I've seen atleast, but will definitely have another look before I swap out the EEC.
Old 12-06-2013, 08:26 AM
jas88's Avatar
jas88
jas88 is online now
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Sounds like a bad ECU to me.
Old 12-06-2013, 10:16 AM
DennisMenace
I don't know if wire colors changed but just keep following the line.
If you can get your hands on a volt meter and or 12 volt test light see if you have key on cranking power on the red. and the yellow power wires , if so see if your getting power out of the relay to the inertia switch on the dark green/yellow wire.
Old 12-06-2013, 11:13 AM
subford's Avatar
subford
subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Check the small black wire with a green stripe at the NEG post of the battery. Odds are it is either this wire not grounded or a bad ECM computer.
Old 12-06-2013, 11:56 AM
jas88's Avatar
jas88
jas88 is online now
If he's grounding the pin on the Self-Test connector and it makes the fuel pumps run, why would he need to check the wiring downstream? That tells me his wiring, fuel pump relay and tank switch are good.
Old 12-06-2013, 12:26 PM
subford's Avatar
subford
Yes that what it says.
But if the ground wire at the NEG post is off or bad the computer will not have a ground to ground the fuel pump relay.
Not sure if the EEC Power relay uses the same wire at the NEG post or not.
If it uses the same wire then about the only thing it could be is the computer or a pushed out wire in the computer plug.
Now if he jumped pin#2 to Pin#6 in the test plug and the fuel pumps ran that would mean the ground at the NEG post is good also.
But I think he said that he only grounded pin #6.
Old 12-06-2013, 01:44 PM
jas88's Avatar
jas88
jas88 is online now
Understood - thanks for the clarification, subford.
Barrakuda
06-05-2016 11:22 AM
otgarza
1997-2006 Expedition & Navigator
02-24-2016 03:25 PM
Travis12384
10-27-2015 09:48 PM
Tim Hodgson
02-12-2015 10:56 AM
rholloman6
1978 - 1996 Big Bronco
12-11-2011 10:16 AM
Quick Reply: No Power to Fuel Pumps!
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
