6.0 Upgrade ideas on a budget
Hey there, I have a 2003 ford f350 with a 6.0. I have a budget of about $5000. The truck is bone stock, and I haven't had a single problem with it other the vains sticking on the turbo. I am looking to see what uprades people have done to there 6.0s and get ideas on mine.
I have a free one for you.
Come on over to the 6.0L Power Stroke Diesel - Ford Truck Enthusiasts Forums
and ask.
No charge
As far as studs go they can wait if you can
EGR delete just depend on your feelings and use.
Scanguage 2 is a MUST have or something that will give you live
data that you can look at when your on the road.
Fluid change is a very good idea and it one of the top things that
should be done along with OEM filters and caps. Don't use aftermarket there.
Having a good time and enjoying the truck should always be top on the list.
Sean
and ask.
No charge
Sean
Sort of, most other vehicle problems can be fixed cheap and within a day or two. The 6.0 on the other hand is normally lots of money to fix and is normally down at least 2 days, some can't get them fixed for up to a month at a time.
I would only do studs if I was doing head gaskets and I would only do head gaskets if I had a blown head gasket. Presuming the truck is currently running perfectly I would do the coolant stuff, the fuel pressure regulator, Scangauge II or equivalent, fuel pressure gauge as far as mechanical upgrades went. I would do shocks, steering damper as far as suspension went (I like the stock suspension height and all that just fine), and for me the biggest bang for the buck on appearance is probably going to be wheels and slightly meatier tires. I don't listen to music in the truck, so I would keep the stock stereo. I just put a cap (Leer 100XQ) on mine that I found used and was a colour match, for $900. I'm liking the extra utility so far, and the cab wind noise is reduced a lot at highway speed.
Brian
Brian
