How Do I Select The Right Tow Strap?
This isn't a great setup. Giving the recovery point so much leverage is pretty far from ideal. You've got it gussetted, so it'll take quite a bit, but at a lot of organized events they don't allow welded recovery points, and this is welded with bad geometry making the forces on the welds pretty high. You'd be safer (and put lower forces on the receiver and frame as well) getting the clevis up directly in-line with the receiver.
It sounds as if you factored in the leverage issue pretty well, and compensated by using the heaviest steel you could find...........With what Nothing Special said, have you considered adding a couple pieces of steel plate on either side of the horizontal bar, drilled out to accept a 1" Clevis pin, then remove the shackle.....You would then have a larger open step plate, and a wider stepping point on the horizontal upper member as well, and of course a truly straight line pulling point...........I bet the look on a Prius drivers face as he's about to hit this chunk of steel is priceless....
I mostly wanted to get a warning out there for anyone looking to copy your setup. It's easy to do something like that wrong (not that you did) so anyone looking to copy ought to think about it a little.
Warn Industries - Rigging Accessories for Jeep, Truck & SUV Winches: Shackle Bracket
A hitch mount, even with no drop, is still welded. Clevis mounts are just a single piece of steel. Again, at a lot of organized events you aren't allowed to use welded recovery points. They really prefer solid mounts bolted to the frame (I don't know why they are usually OK with attaching to a receiver hitch when the receiver is welded, but that seems to usually be an exception).
And it's not that welds are too weak, it's that they MIGHT be too weak. At organized events when they have a lot of people getting pulled out and not a lot of time for tech inspection they find it easier / safer to determine if solid material and bolts are strong enough than to determine if welds were done properly.
#28
Received 3,099 Likes
on
that hitch with the bar on bottom would do more damage in a rear end collision that you would get with nothing at all.
with the amount of drop on it, the mechanical leverage it will provide to the receiver and truck frame is going to be very extreme, and the receiver will be ripped off the frame and most likely there will be frame damage in a rear end collision.
i had a simple 4 inch drop hitch on the back of my 02 when i got hit by a jeep doing 60 mph.
the hitch hit the engine block pushing it and the trans out of the frame under the seats.
it destroyed my hitch, twisted the receiver and bent the frame on the truck.
nothing severe, but enough we had to straighten it before bolting the new receiver on.
#29
#30
on
48fordcoe
18
12-05-2009 03:38 PM
aquaholic
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
22
03-21-2007 05:29 PM
