My New 1997 F-350 460, need some help
Old 12-02-2013, 12:31 PM
Bhollins3's Avatar
Bhollins3
Bhollins3 is offline
wouldnt i see gas leaking if the front tank is pushing gas to rear if the rear is already full? i have no leaks. im going to check everything out again when i get home and see if the rear tank is slamed full.
it has brand new fuel pumps assembly's (with check valves)
Old 12-02-2013, 02:49 PM
mrrish79's Avatar
mrrish79
mrrish79 is offline
Congrats on the purchase!
Old 12-02-2013, 04:11 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
Seems like you probably would see it, so this might not be your problem. It was just something to look for.
Old 12-02-2013, 06:38 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Third, the back glass latch is gone. What do most of you all do? Go to the junk yard?
Check your local auto part store. Dorman makes a sliding window latch kit for trucks of this vintage. I saw 2 different part numbers and the application listing was a little wonky. If there is anything left of the old latch take it in with you to match it up.
Old 12-11-2013, 04:06 PM
Bhollins3's Avatar
Bhollins3
Well turns out my rear fuel tank is actually leaking fuel. Doesn't matter how much fuel is in it, still leaks. Looks like its coming from the top and rolling down the side toward the motor. Any suggestions?
Old 12-11-2013, 04:14 PM
BigBlockF350's Avatar
BigBlockF350
BigBlockF350 is offline
If it's from the top at any fuel level then you probably just need to take a look at the tank connections. You could also have a pin-hole leak in the fuel line up there, but I'd bet it's just a line connection.
Old 12-11-2013, 04:25 PM
Bhollins3's Avatar
Bhollins3
Think I would have to drop the tank completely or lower it? Never done one on these trucks.
Truck is on 35s so I have plenty of room under there.
How much can u usually lower the tank before connections have to be unhooked?
Thanks everyone
Old 12-11-2013, 04:40 PM
BigBlockF350
Thanks everyone
You may be able to shine a light in there and see where the leak is coming from. Whether or not you can get to it may be another story... I've managed to get to mine from underneath coming in on the passenger side when I ran a fuel line to mine.
Dropping the tank really isn't difficult. Just make sure the tank is empty or close to it so you're not dealing with tons of weight. You should be able to take the fuel lines out of the clips on the frame and lower the tank all the way down if I remember correctly.
Old 12-11-2013, 04:56 PM
Bhollins3's Avatar
Bhollins3
That would be nice if I could. Any one know for sure?
Old 12-11-2013, 04:59 PM
Bhollins3's Avatar
Bhollins3
On check valves, if the front tank is pushing fuel into rear while using the front tank then the rear check valve is bad right? Or opposite.
Old 12-11-2013, 05:02 PM
BigBlockF350
I know that I pulled one on an '86 F350 and didn't have to disconnect the lines until it the tank was on the ground. I believe it was still similar through '97 at the end of the old body style. That was the same tank I put onto my '88 and it was a direct fit.
Old 12-11-2013, 07:16 PM
Bhollins3's Avatar
Bhollins3
Am I on the right track with the check valves? Front tank fills rear so front tank check valve is bad?
  #28
Old 12-11-2013, 10:33 PM
BigBlockF350
Yeah, you've got it. Last time I checked those units were around $90 I think.
  #29
Old 12-12-2013, 08:52 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
Opposite. Front tank is sending fuel to the place that has the weak check valve which would be the rear in this case.
  #30
Old 12-12-2013, 09:08 PM
Island'r's Avatar
Island'r
Island'r is offline
x2
Welcome to the 460 club... She'll pass anything on the road except a gas station... Of course you've got enough power to pull your own tanker truck behind you
Quick Reply: My New 1997 F-350 460, need some help
