My first 6.0...What to do?
Hey guys, I just bought my first 6.0, and I must say I'm a bit nervous. After racking up over 250k each on 6 different 7.3's, I've jumped into a new game here. The truck is a 2007 Crew Cab Dually. I bought it about a month ago with appx 60,000 miles on it, and I've already put over 6,000 miles on it. So far, no problems other than the 11 miles to the gallon. I expected better. The only mod power wise that it has is an SCT tuner which I love so far. Currently it is a personal truck within two years it will be cycled to a work truck. In that two years, it will be (and already has been) hooked to loads grossing up to 40,000 pounds. I want her to last, and be reasonably low maintenance if possible.
My current plans are:
Cold air intake
EGR Delete
EGT Probe
Head Studs
Change tranny fluid
Upgrade brakes
Am I missing anything? What do I need to watch for? What are some potential problems? Is the 6.0 up to what I've been using the 7.3's for?
Thanks!
Cold air intake
EGR Delete
EGT Probe
Head Studs
Change tranny fluid
Upgrade brakes
Thanks!
Honestly, I haven't played with the SCT much yet. I just got it because I can change to custom tunes down the road, and I can turn off the CEL when I do the EGR delete.
NOW, why not do the head studs now, if I'm going to be towing like that? I've been told (I know most people just run their mouths and don't know) that if I do the studs one at a time now, I'll probably never have gasket trouble.
Gauges that monitor live time data is a must for the 6.0L. I use ScanGauge 2, other's like dashboss. They allow you to keep a eye on things and trouble shoot the motor as you drive. A very important thing to do is to keep a good set of batteries in it and a good charging system. Knowledge is the key to this engine and this is the place to find it. Read on my friend and welcome to the forum.
The most common reason for headgasket failure is EGR cooler rupture.....if you delete the cooler, you greatly reduce HG failure.
Save that stud $$ and get
blue spring upgrade
Fuel psi gauge
some sort of scantool to read live data and retrieve codes
FICM rebuild with Atlas 40 tune from FICM Repair.com - Your Source for FICM Repair
coolant flush - use CAT EC-1 rated coolant
chmage both fuel filters-use only Racor or Motorcraft filters-install updated HFCM drain plug
upgrade alternator if you have a single 110 amp
new batteries if yours 3+ years old
there's more but I'm watching football....sorry
blue spring upgrade
Fuel psi gauge
Not sure anyone else caught this, but if you will be towing 40k lbs you will want to use the unlimited tow tune, which is just the stock tune.
I do believe the studs are a good idea if you have the funds, not sure about doing them one at time though.
Gauges, like SanGauge2 is a very good idea, definitely recommend it.
The stock air filter is a good unit, does a great job protecting the turbo.
Snap To Connect
It's the fitting coming off of the HPOP feeding the injectors. They are prone to failure. There is and updated replacement that's normally trouble free.
You may want to get a warranty history report to see it has been replaced.
