Do the 6.0s have CPS problems like the 7.3s? My neighbor has a 6.0 and described to me what it was doing, and sounds exactly like when our CPS is going/gone bad. He said it would quit going down the road, then start back up while rolling....been doing that for a while. Then the other day it quit and would not start back up.
No they don't Bill. I asked that question in the 6.0 section and was told they don't have CPS issues like the 7.3
Ok, I wasn't even sure if they had a cam position sensor or not. Aaron said he knows they have a crank position sensor, but unsure about the cam position sensor. Thanks!
He also said after going down a long mountain and getting back on flat ground at the bottom, it would start missing and running rough. My cousin told him that was bad injectors.
FWIW, I had a 6.0 do the shut-down start-up routine too. Usually you'd hit a bump or a bridge joint and it would shut down. Turned out to be bad/burnt injector wiring harness. I wanna say it was the valve cover gaskets. I don't remember since it dropped a valve and grenaded itself not long after that.
