my first scare
my first scare
out driving tonight,, well been out all day really anyway we was out tonight and i went over a bump it the road must have been a good one , and then my passenger door popped open ,, yeah scared my wife , don't know if she will go back with me now ,, i stopped and close it from outside kinda hard ,, it was fine on the way home ,, just when you think you got something fixed and go to the next thing , you have to lick your cafe over , so i will be back on the door latch , i wish santa would bring me a set of them new style latches
thanks guys
thanks guys
Could be that it's worn out or you don't have the door adjusted high enough, also check the little pin / adjuster in the back of the outside door handle to make sure it's not adjusted too far in. They also make shims that push the striker plate out a bit. If it's adjusted correctly and no worn out parts, the door should not come open
Hey Robo,
We also experienced the fun of a door opening after going over big bumps and around corners. Our '50 door has two latches in it - your door has to sit perfectly in there to catch both latches. If you only catch one - the door flies open at the most scary of times.
Our's is due to the door not being perfect in the opening & the rubber door seal being a little too stiff/thick. I think we have it latching correctly right now - but I advise passengers to buckle up.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
Hey Robo,
We replaced the latch hardware that is on the post. We got it from Early Midwest ford but I'm sure there are other suppliers. It was pretty cheap & I really wanted that door to stay shut. There is a screw you can adjust that moves it in our out - just took some time fiddling around with it.
We wanted to drive ours while waiting for parts so we swapped the driver's side
post latch that worked over to the passenger side. It's an interesting design - I will probably break down & get better modern latches at some point.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
