Harsh shift to second gear
Old Jun 23, 2003 | 08:18 PM
mtntop's Avatar
mtntop
Unhappy Harsh shift to second gear
My 1995 F-150 with 5.0L engine and aod trans has a somewhat harsh shift from 1st to 2nd instead of a smooth shift if slams into 2nd.Any help would be appreciated.
Old Jun 23, 2003 | 09:17 PM
Gwrenchplus's Avatar
Gwrenchplus
MTNTOP i have a 96 thats doing the same thing. mine does it real often but put not all the time. I dont know what causing it. I have asked about it but no one has been able to tell me what is wrong. I have had the codes checked none found.I have the trans serviced every year maybe someone will be able to help with the problem
Old Jun 24, 2003 | 03:50 PM
The Tree's Avatar
The Tree
The problem most likely lies in the valve body. Its on the bottom of the tranny so you can clean it yourself of you can just take it to a shop and they'll clean it out for you.
Old Jun 24, 2003 | 08:38 PM
LxMan1's Avatar
LxMan1
I agree, could be a valve sticking the letting go all at once causing the hard shift. I like them shifting quick anf firm myself, but it shouldn't do this on an unmodified tranny.
Jimmy
