Few tq specs I can't find.
Thanks! just what I needed.
Hoping to have the motor fired up by the end of the week. On the old engine, there are small parts of the crank and rods that you can tell got hot, blueish color in a few spots. No idea what happened there, the thing never did run right, and I bought the truck new. Always had a very slight miss and at certain rpms the truck would shake pretty bad. Guessing there was something wrong with it from day one It always ran like a raped ape though.
I'm putting new injector cups in since the motor is out, any tips on cleaning the cup bores? Just a small wire brush?
Also, I think the new cooling jet bolts come with loctite already applied. Which if that's true, are you know the bolt will turn harder, will that have an effect on the final torque number?
Since its taking more tq to turn the bolt in because of the dried loctite. Or am I over thinking this?
on
I wouldn't fret over the dry Loctite. Just put them in and torque to specs.
ernwa
16
08-07-2018 06:58 PM
jstihl
05-19-2017 07:03 AM
Ira Brown
08-10-2010 07:54 PM
buffjc
01-01-2008 07:00 PM
