'92 F350 defaulting to defrost only
Ok so recently (just in time for winter) my truck is only blowing out defrost.
Now things ive done. The white vac line under the hood was shot so i replaced about a foot of it with new line.
Recently i took out the AC unit and replaced with a bypass pulley if this could affect it.
When i move the vacuum control right above the passenger foot well the air will come out of vents.
I check the lines for leaks and cant find any.
Anyone have places to look ?
(pic of little vacuum control that will let me blow out of vents manually)
[IMG]<a href="http://imgur.com/FN8BxLw"><img src="https://i.imgur.com/FN8BxLwl.jpg" title="Hosted by imgur.com"/></a>[/IMG]
[IMG]<a href="http://imgur.com/Lm2jzAy"><img src="https://i.imgur.com/Lm2jzAyl.jpg" title="Hosted by imgur.com"/></a>[/IMG]
Ok so i looked into it last night. Started tracing some lines. And found alot of problems clearly from the previous owner. Can you guys clarify what the hell he did here. Also i removed the AC pully and let the lines sit there idk if that would effect vacuum.
[IMG]<a href="http://imgur.com/PAiM0Q5"><img src="https://i.imgur.com/PAiM0Q5l.jpg" title="Hosted by imgur.com"/></a>[/IMG]
<a href="http://imgur.com/5wwHDTG"><img src="https://i.imgur.com/5wwHDTGl.jpg" title="Hosted by imgur.com"/></a>
<a href="http://imgur.com/s4GVQdb"><img src="https://i.imgur.com/s4GVQdbl.jpg" title="Hosted by imgur.com"/></a>
