what size engine does this 97 f 250 hd have?
The 351 will get 12-14 mpg at BEST lightly loaded...
The 460 will get 10-12 mpg at best lightly loaded...
Put the 351w truck under a big cab-over camper and pulling a boat/gear up high mtn. passes, it will get 7-8 mpg and struggle..........The 460 truck with the same load will still get 10mpg and not break a sweat.
Just a old guys experience.
I can drive at 60 down the highway, cruise on, turning 1900 rpm and get 13 14 pretty reg with my current 460. We own some property that's 65 miles from where I live & drive up and back almost every week. Check the mileage when I get home and its pretty constant. It'll go down to 10 when loaded with firewood on the way home. I live in a small town & don't do much city driving.
96 f350 crewcab 4wd 460 5speed 3.55 gears and 33" tires.
Around town and HARD on it , I never saw below 10mpg,
Highway crusing , cruise set at 70. 13.2mpg
97 F250 reg cab 4wd 351 5speed 4.10 gears 285 tires
Around town 9-10mpg(CONSISTANT) normal driving
Highway cruising (NO cruise) doing 65-70. 12mpg
You do the math
You do the math
I would get the 460cu. Bigger engine usually means bigger and stronger running gear. I drove around in a company's bone-stock 1996 f350 CC 460, E4OD, 2WD, with a shell and it got constantly 13-14mpg at 65mph empty with 4 people. My 1994 f350 CC, 7.3IDIT, E4OD 4wd only gets 1mpg better. The only reason I would get the 351W would be if I was concerned about weight; which you arent since its a 3/4T truck.
That said, i wouldnt mind the 460 if i only used the truck to tow or haul, but for commuting, it just wouldnt make sense.
Completely worth it if you are hauling all the time, but not if you haul air half the time. it should depend on your use of the truck.
I believe, by the time you get into a 3/4 ton truck, it's not really a daily driver type vehicle anymore, it's a piece of heavy equipment.
Get the biggest engine available.
That being said, the 351w is a great motor, but if all your truck does is haul a camper and do RV duty like mine, it just makes sense to go with the 460.........JMO.
ok well what engine would you guys want for a daily driver?a 351w or a 460?i pick the 351 why would you want a 460 if your not pulling anything like me?i mean I like the truck the guys selling I just feel the 460 will drain my pocket of cash for gas money.you really would take a 460 as a daily driver keep in mind in not using it for towing at all.how many of you guys drive ra 460 as a daily driver and not for towing?anyone at all?i bet not.
I have 8 F350s. and you know what i drive on a daily basis? A RANGER that gets 18-20mpg
