Nightmare confirmed.... !!! Options???
Old Nov 29, 2013 | 12:32 PM
UcaN's Avatar
UcaN
Hello all
I have been having cold start smoke/miss (smells terrible) for a few months. I figured it was an injector that had gone south since it did start making a funny noise. So i ordered a set of Reman single shots w/hydra chip Injectors and installed them, only to still have the cold start smoke/miss. I checked the usual....( boost leaks, fuel leaks, all sensors check ok according to AE, No excessive blow by, harnesses, and VC gaskets ohm around 3.2 - 3.4 at the 42 pin connector, fuel pressure at 65psi @idle, hpop 500+ @idle, does not consume excessive oil, degas bottle is clean, does not consume coolant.
Went ahead and did a compression test... these are my results.
2. 360
4. 250
6. 365
8. 360
1. 365
3. 370
5. 375
7. 365
Would it be possible it is a valve rather than rings....?? If so how do i check for that...??? (leak down test??)
Finally, what are my options besides a short block from ford??? Is the RiffRaff rebuild kit the way to go???
I have an engine out of an OBS that i could use. Are the blocks interchangeable???
Thanks
Old Nov 29, 2013 | 12:46 PM
trk98's Avatar
trk98
If there's no excessive blowby then it would almost certainly be valve related. Did you put the copper washer in for the injector on that cyl? Somone else can probably chime in about how to test for it. If the obs heads are compatible you could get a fresh valve job on those heads and have minimal down time. How many miles does your SD have?
Old Nov 29, 2013 | 12:48 PM
UcaN's Avatar
UcaN
Yes, double check for the washers when i installed them....
how do i check to see if it is valve related or piston related??
Old Nov 29, 2013 | 12:56 PM
trk98's Avatar
trk98
I think you could remove that glow plug, pressurize the cylinder with both valves closed using compressed air, and listen for air flowing either out the intake, exhaust, or crankcase.
Old Nov 29, 2013 | 01:10 PM
UcaN's Avatar
UcaN
ah, gotcha.
Do you know if the OBS engine blocks are interchangeable with the new 7.3's ????
I guess i can swap my parts to the early block if i have to, while i rebuild my block....
Old Nov 29, 2013 | 01:12 PM
trk98's Avatar
trk98
No I don't, sorry. I'm sure the regular heavy hitters will be able to elaborate better on your situation. Ill be following
Old Nov 29, 2013 | 01:13 PM
HKusp's Avatar
HKusp
The blocks are interchangeable, but there are a few things that need to be swapped.
It's all discussed in this thread. Click here
Old Nov 29, 2013 | 02:24 PM
UcaN's Avatar
UcaN
Thanks ....
Reading thread now.....
Old Nov 29, 2013 | 04:22 PM
Bonanza35's Avatar
Bonanza35
I think if you follow trk98 advice you find where it is leaking from.
Old Nov 30, 2013 | 10:08 AM
BadDogKuzz's Avatar
BadDogKuzz
Like it was already said since you don't have blow by than I would say it is a valve issue. Personally I think it would be easier to pull the heads and do a valve job. But once you get the heads pulled you can check to make sure the valve issue did not involve valve smacking the priston. And if that is the case I would say go to a back up engine until you can go through and rebuild that one.
Old Nov 30, 2013 | 03:31 PM
Christof13T's Avatar
Christof13T
If you can... have it on a stand to pull the heads.
1. It will be much more manageable.
2. It will already be out if you discover cylinder/piston issues.
3. Fighting with the weight of one of these heads is bad enough while on a stand... let alone in the truck.
Since you are already going as far as pulling heads...
I would pull the oilpan and give everything a good look.
Maybe welded jets?
Doing the changeover with an obs motor is gravy.
I think the fuel pump lobe port took a 7/8 freeze plug.
Just in case the diagnosis is bad...
Take lots of pictures!
Old Nov 30, 2013 | 04:55 PM
BlueScab's Avatar
BlueScab
Drop a little oil in the cylinder and re check compression. If the number goes up the rings are bad. If it dosen't change its a valve issue.
Old Nov 30, 2013 | 06:53 PM
sand_fiend's Avatar
sand_fiend
Not too much oil or you could hydro lock the motor..
Old Nov 30, 2013 | 09:39 PM
UcaN's Avatar
UcaN
Thanks guys. I will be doing a leak down test and add oil to the piston as advised, and go from there.
Truck runs great after it warms up.So hopefully it is a valve issue.
I will report back with my findings.
Again..thanks
mattdoc88
Jul 24, 2019 04:42 PM
adamax21
Feb 13, 2014 12:32 AM
spcw1234
18
Jun 12, 2011 07:56 PM
whits
Aug 3, 2009 07:53 AM
350ford4x4
Aug 29, 2006 08:57 PM
