welding a frame
Old Nov 26, 2013 | 06:31 PM
bmuhlbach's Avatar
bmuhlbach
I bought a Miller 211 last month $1136.00 there is a rebate you have to buy the welder and $150- in Miller equipment to get 10% back so you could get a spool gun for welding aluminum. The 211 could also run both flux core or the other. Hobart is made by Miller has a dual 110/220 it might be the 190.Lincoln has a sale going and they have a dual as well.
Old Nov 26, 2013 | 07:02 PM
f1001969mike's Avatar
f1001969mike
AWESOME!!!, thanks area351 thats just the kinda info i was lookin for!
Old Nov 26, 2013 | 07:28 PM
Ford_Six's Avatar
Ford_Six
Yup, those Millers are pretty sweet. Some machines have auto-link, which means you can basically plug it into anything from 110v single phase to 440 3phase and it'll take what it needs automatically. My Dynasty has that, and it is very nice.
Make sure you clean away any rust, get it to shiny metal, bevel the edges, and also pre-heat. Any weld shop worth anything should have temp sticks, they are little wax crayons that melt at a controlled temp. Use a propane torch to bring it up to about 200*, but make sure it's below 500* if you are making multiple passes. Apply heat, touch the temp stick to the surface about 1/4" away from the weld area, and if it leaves a smear you're above the temp. If it just leaves a chalky mark, you're below the temp.
Old Nov 27, 2013 | 06:02 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just another MillerMatic 211. I have bought three different welders from them and completely pleased. Fast free shipping and good to deal with. http://www.ebay.com/itm/MILLER-MILLERMATIC-211-W-AS-MIG-WELDER-PKG-907422-/141008456082?pt=BI_Welders&hash=item20d4c24992
Old Nov 27, 2013 | 10:23 AM
grinnergetter's Avatar
grinnergetter
I have both the Hobart 140 and the 211 Miller set up for 220. Welding with the Miller is light years ahead of the smaller mig although I'm not a fan of the autoset. I prefer to adjust manually.
Old Dec 9, 2013 | 09:09 PM
f1001969mike
thanks guys for all the help, after doing a lil research, im gonna go with a hobart 210 MVP, just to check again this thing will be enough to weld up some c-notches? its a 220 welder
Old Dec 9, 2013 | 09:22 PM
HIO Silver's Avatar
HIO Silver
Yes. Plenty.
Btw, Miller owns Hobart. I figure some of the internals are the same. The case looks surprisingly similar.
Old Dec 9, 2013 | 11:10 PM
f1001969mike
yeah i was readin about that its just a slightly less expensive miller, well excellent then, now i can weld my frame WITHOUT burning my house down :P cant wait to get this f-100 on the road
Old Dec 10, 2013 | 09:15 AM
bmuhlbach's Avatar
bmuhlbach
I think youll be good with the 210.My buddy has the 180 and loves it when I was looking he recommended the 190 Hobart.I was looking at them at tsc .
jlang
Nov 19, 2009 10:16 PM
2pfspiff
Sep 15, 2007 12:13 PM
kld1958
Jul 20, 2007 08:59 AM
OilLeaks
Sep 6, 2006 02:04 PM
77460ford
Garage & Workshop
19
Apr 6, 2005 09:11 PM
