Block drain plug advice needed...
I use antiseize on every Nut or Bolt as I repair things as they go out
The worst thing I have come across so far is when I did my Ball Joints that was a Nightmare LOL
My exhaust manafolds are next on the hit list they should be FUN
The little suckers could not withstand the judicious application of an air chisel - absolutely nothing else worked.
Tomorrow I'll try to put the starter back on....that top bolt is hard to get to, for some reason. I had to remove the RF wheel, plus the inner fender splash shield to even be able to see what I was doing.
I used the Fumoto valves with a nipple that sticks straight out -108-N, I believe.
It sure looks like it will hit the starter - does it???
Definitely going to add some 3/8 hose and a clamp before the starter goes back on. If the starter ever quits someone else will have to fix it.
Miller time.
I thought about removing all of that stuff to get to the top bolt. Then I realized that the block heater wiring unplugged and i could get a deep well socket and long extension in there.
Miller time.
I am one whipped puppy....
Many thanks to all of you for the help, pointers, and general advice. I wouldn't have wanted to try it without all of you looking over my shoulder.
Bill
