1997 F250 HD 4x4 Rust-o-ration
#107
#108
Even though it had the plow mount until I bought it the truck hadn't had a plow mounted on it in the last 10 years. It also was used lightly before that so there wasn't much of any sag to the front end.
#112
Because my first several vehicles were AMCs. My first car (which I still own) was an '84 Eagle wagon. I also owned a 360 powered '83 Spirit, a '76 Gremlin, and 4 other Eagle wagons. My girlfriend at the time also had an Eagle wagon. My buddy had over 20 AMCs. Before they all died up here in WNY he and I owned or flipped quite a few.
#113
Had my buddy at work cut the holes and tapers on the push bar side plates with the waterjet. Also cut my initials into the sides for fun.
Mill scale ground off getting ready for tubes.
Here is the lower tube/receiver mount.
I'll add the receiver last.
Here the tubes all cut and tacked in place.
1 1/2" tube on top, 2" in the middle.
#115
#116
Still haven't been able to do much on the truck due to other projects and the SD cab on the back, but did make some progress. I got the Alcoas mounted up over the weekend.
I also got the brush guard painted and installed with the hitch.
With the 285/75R16s the truck towers over my 2WD F250!
I just got the SD cab off the back yesterday so hopefully I can get back on finishing the truck this weekend.
#117
#118
Been a little while since I updated, but other projects and work got in the way. Anyway, I finished the wood in the flatbed. It's treated 2x8s.
The rear light panel installed with trailer plug and mud flaps.
And the first time on the road. Don't mind the step on the bumper guard. I was using it to work under the hood. It won't be installed most of the time.
With new side panels. The wood will all be painted gloss black as soon as it dries out a little.
Spare tire mounted.
Painted floor. Sides are next.
Spare tire mounted.
