1997 F250 HD 4x4 Rust-o-ration
#46
This weekend I put the engine back in the truck.
Then started to add all the top and accessories including new EGR tube and vacuum hoses.
Then I did the smog pump eliminator kit.
And with everything buttoned up. Spent a lot of time repairing the dipstick tube and all the metal brackets that attached to the manifolds as they all were rotted off.
#49
#52
I used a Proform 68110 piece from JEGS. It was $55 and is for a Mustang. I also had to change the pulley from the Mustang pulley (smaller dia.) to a 5.8L AC idler pulley. I made another thread about the how thing yesterday with more pictures and details. It's titled "5.8L SMog Delete with Pics."
#53
Used Herculiner to coat the cab floor. I'm just going to run this with some floor mats, no vinyl factory floor to hold in moisture.
Here is how I replaced my rotted out original core support with a combination of the center of a '91 support and the ends of a '94 support. Here are the two side by side.
After careful measuring I cut what I needed off the '94 support. You can see how much wider the '87-'91 support is at the fender attachment.
Committed now!
Converted to '92-'97 style.
Checked the fenders and everything lines up as it should.
A little paint and undercoating.
Going back together nicely.
Committed now!
#57
#58
#60
Updates? A lot this weekend. First off I got the door jams and cab corners painted.
Then I was able to hang the passenger door.
And regap the fender to the door.
The door I used came off a truck with the smaller mirror so I had to mount and drill the door for the swing away mirror.
Seats! This truck came with a roached bench seat. I wanted the 40/20/40 buckets and found these.
But, in order to mount them you need this. Luckily, I found the seats and pan on an old Craigslist ad and the guy still had them. I paid $200, but the reg cab pan is hard to find and the seats are in good shape and the right color so I guess that's not too bad.
Here's how they go together.
And I also remounted the 4WD shifter boot.
