Question: Independent Rear Suspension on mid-50's
Tbird and cougar are coil springs. Mk8 has factory airbags. Most replace the Lincoln bags with aftermarket though.
I didn't do it but looked long an hard at it, before going the explorer 8.8 route.
Also be careful choosing tbird IRS. They have 7.5 and 8.8, and different ratios. Do your homework. Plenty of info on the web.
Sorry, I guess I didn't read the original ? well enough. Kugel is pricey, but if you can swing it, i can't imagine you'd be sorry about the quality. I think you might find other places to spend the $9k you save if you go another direction for IRS.
Hey Jerry,
Might be good to see what you are working with over there in Anteater territory. Our '50 was in need of a lot of TLC - we ended up spending a lot of time & effort on the IFS, Cab, Doors, Bed, & engine/trans. We didn't spend much on the rear end - went with an Explorer 8.8 for the rear - $125 at a Salvage yard. It works just fine for cruising & oddjobs.
I might go with a Currie rear diff. if I just wanted to spend some money.
Good luck over there in Irvine.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
About the only body part on the truck that will be "real"/"original" will be the cab. The rest will be fiberglass replicas - lighter and cheaper;-)
I have a small site that I've been using to track what I plan on using - mailordertruck.com.
The current plan is to mostly assemble a truck from scratch - the only thing that will be from a 1956 Ford F-100 will be the cab (doors too will be replicas) and that's only because with the very limited searching I did I couldn't find a replica. I'm hoping that the real cab will be "enough" to use the title from the truck that the cab came off of.
I bought a 95 "T" bird IRS for $125, complete to the last bolt and Installed it into my 55 F100.
The team 321 IRS kit is one way to plug it in and probably the easiest way but I have this thing about hacking into my frame so I did it MY way. See my build thread for more info.
I think that a full IFS and IFS under my truck will be soo nice but then again, it still sits on jack stands.
A nice fiberglass '56 cab is about $6k. BeBops makes one. Here: http://www.hotrodssuperstore.com/19forf1cab.html
I assume that you've looked into a Jaguar suspension. They do ride nicely.
I started looking at the jaguar suspensions earlier.
CharlieLed:
I'm a bit disappointed as I didn't think there were any others (though secretly I would have been shocked if I truly were the first;-)
It does look awesome and it's something I want to emulate.
Do you know how he had it registered - as a kit or something else?
CharlieLed:
