Resetting the PCM after Repairs are made - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2009 - 2014 F150
Reload this Page >
Old 11-17-2013, 01:04 PM
makuloco2000
makuloco2000 is offline
makuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to allmakuloco2000 is a name known to all
Here is the definitive how to guide to clear all the old bad shifting and idle habits from the defective parts you have changed out. A simple battery disconnect will clear codes but not the adaptive shift and idle strategy. Many times the vehicle will exhibit the same concern even after replacing the part due to old "Learned Value". Take a moment to watch the video and you will then finish the repair job right!
Old 11-18-2013, 08:35 AM
03_PSD
03_PSD is offline
03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.03_PSD has a great reputation on FTE.
That's good to know, thanks for posting!
Old 11-25-2013, 12:32 PM
makuloco2000
No problem, of course dual battery setups require both batteries be disconnected. It's fool proof any year any model that's why we stick with this procedure.
Old 11-25-2013, 08:11 PM
DLTtoday's Avatar
DLTtoday
DLTtoday is offline
DLTtoday is starting off with a positive reputation.
Good info to have. Thanks for taking the time to share.
Old 11-25-2013, 09:49 PM
makuloco2000
No problem!
Old 11-26-2013, 08:19 AM
johndeerefarmer
johndeerefarmer is offline
johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.johndeerefarmer has a very good reputation on FTE.
That works fine but using my SCT programmer and doing a KAM reset is easier and faster
Old 11-26-2013, 10:00 AM
makuloco2000
Whatever works best for you.
Old 06-30-2014, 11:24 AM
EBXLTF150
EBXLTF150 is offline
EBXLTF150 is starting off with a positive reputation.
Would an alternate procedure be simply turning on the headlights once the battery cables are disconnected? Wouldn't that drain any leftover voltage remaining in the PCM, etc and accomplish the same thing? I would assume so, but just checking...
Old 06-30-2014, 12:57 PM
makuloco2000
Years ago yes absolutely but nowadays all the head light switch or defrost switch or any other switch is simply sending a ground signal to the bcm then it is up to the bcm to turn on the relay and headlamps. That cannot happen if the bcm is not powered up so you flick the headlight switch on and you are doing nothing on any of the newer cars since the 90's.
Old 06-30-2014, 01:00 PM
EBXLTF150
OK, understood.
Old 10-11-2018, 10:36 PM
Robert Papa
Robert Papa is offline
Robert Papa is starting off with a positive reputation.
Sct?
I have an SCT X4. Where in there does it have to do Kam reset
makuloco2000
Escape & Escape Hybrid
07-25-2017 11:47 PM
Berardini2121
1978 - 1996 Big Bronco
11-04-2016 10:03 AM
robertom18
04-20-2016 10:44 AM
Sous
11-21-2015 07:59 PM
makuloco2000
6.4L Power Stroke Diesel
01-21-2014 09:27 AM
Quick Reply: Resetting the PCM after Repairs are made
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
