Rebuilt fuel bowl and now no start
Old 12-29-2011, 09:29 PM
97f250_95120's Avatar
97f250_95120
97f250_95120 is offline
I rebuilt my fuel bowl today and replaced all of the hoses from the pump as they were cracked. The heater was the only thing broken so I didn't hook it back up. The truck won't start now. The fuel bowl is full of diesel. Diesel sprays out of the shredder valve. Checked the oil in the in HPOP as well and it is good. Any ideas?
Thanks
Ed
Old 12-29-2011, 09:36 PM
Action4478's Avatar
Action4478
Action4478 is offline
Check the wiring to the IPR first , & also make sure the main harness on the side of the bowl is plugged in
Old 12-29-2011, 09:41 PM
97f250_95120
The wiring on the IPR is plugged in and the harness is also plugged in.
Old 12-29-2011, 09:50 PM
Action4478's Avatar
Action4478
are you still getting a WTS light?
Old 12-29-2011, 09:59 PM
97f250_95120
Yes. I did notice that the fuel filter light is on when cranking. Never seen the fuel filter light before.
Old 12-29-2011, 10:24 PM
Action4478's Avatar
Action4478
MY bad I see you said the bowl was full .. WTS is the Wait to start light ...
Old 12-29-2011, 10:28 PM
97f250_95120
No. I cranked the motor for maybe 10 seconds and then realized I needed to add fuel to the bowl. I'm guessing I've got air in the injectors.
Old 12-29-2011, 10:56 PM
97f250_95120
The WTS light is on as well when the key is first turned.
Old 11-01-2013, 11:33 AM
Jhenry09's Avatar
Jhenry09
Jhenry09 is offline
I am having the same issue. I rebuilt the fuel bowl and replaced a bunch of lines. I pre filled the bowl and the truck started right up and ran for 4 -5 minutes. and then was starved of fuel and died. the bowl is full of fuel and I have cranked and cranked but it wont start. the hpop reservoir is full and the wts light works normal and all fuses are good.
I really need this truck running soon. any advise?
Old 11-16-2013, 10:26 AM
BBslider001's Avatar
BBslider001
BBslider001 is offline
So whatever happened with this? I want to rebuild mine as well but don't wanna have the same issue. It's my only vehicle at the moment.
Old 11-16-2013, 05:04 PM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
I can't think of anything but heres a bump for yuh.
Spktyr
02-02-2016 01:57 PM
finerant
04-16-2015 12:17 PM
don77
12-08-2009 09:09 AM
Peterson
01-18-2005 08:12 PM
Quick Reply: Rebuilt fuel bowl and now no start
