Here it is boys! My new shop toy!
#76
#77
#78
#80
#83
What method do you use, Dave?
Personally, I like to use a drill big enough to drop the head of a stainless bolt down to the appropriate depth to have the threads up at the appropriate height for a washer and nut. Then, fill it with Pour-Stone (or the like).
Stainless studs sticking up out of the concrete.
Of course, that won't work this time.
I have both 3/8 and half-inch Milwaukees, though the half-incher is developing something amiss with its armature.
Pop
Pop
#86
I had a 1-1/2" bit going through a 8-inch wall at the local high-school shop building (instructor wanted to bring in air from an outdoor compressor), and hit a bar. All I could do was move the hole. That stuff is TOUGH!
Structural (foundation) epoxy is good stuff. I sometimes use the Hilti stuff. I don't use their anchor studs, however.
Otherwise, it's PourStone, which I believe is over 8000 psi grouting. If it's down a pear-shaped hole it works pretty well.
Pop
Pop
