Sponsored by: Real Truck
Which Truck?
Old Nov 13, 2013 | 05:22 PM
mdredneck's Avatar
mdredneck
Which Truck?
So probably not the best first thread of all time but I need some opinions. Tomorrow I'm buying one of two trucks. 2002 f250 5.4 auto 4x4 100k clean as a whistle or 2002 f350 diesel 6spd 250k pretty clean. I will be driving this truck maybe once a week, hauling trash from jobs, and towing skid loader maybe 10 times a year. After having hot rodded 7.3's and recently a duramax I know that the 7.3 will have more maintenance costs but will tow better. I don't want to add any performance parts just a reliable truck that will get me where I need to go and can haul 10k lbs every once in a while. any suggestions? How does the 5.4 tow heavy loads and how reliable is the automatic? thanks
Old Nov 13, 2013 | 05:38 PM
redford's Avatar
redford
FTE Leadership Emeritus
Hello mdredneck and welcome to FTE.
I tow 10k+ with my 5.4L on occasion, but most of the time the trailer load is under 9k. I love my truck, but the 5.4L is not for everyone.
The 2002 isn't as powerful as the 2005+ engine, plus the automatic transmission was a 4 speed. 2005+ trucks got a better 5 speed with a deeper first gear.
A 7.3L with a manual transmission is hard to beat when it comes to general reliability and overall versatility.
Old Nov 13, 2013 | 05:42 PM
Bigpipes 35's Avatar
Bigpipes 35
Both are going to be good trucks but for what you are doing I think the 5.4 would be the best fit, I tow 10,000 pounds with mine all summer long and it never misses a beat or complains.
Old Nov 13, 2013 | 06:09 PM
PSDlongbox's Avatar
PSDlongbox
7.3 without the Achilles heal that is the 4r100. No question. 7.3 all day.
Old Nov 13, 2013 | 06:15 PM
Bigpipes 35
As you can see the gas vs diesel has already begun, Drive them both and pick the one you like best. You are not going to get an unbiased opinion on this subject so get what you like and enjoy..
Old Nov 13, 2013 | 06:18 PM
mdredneck's Avatar
mdredneck
Yea the only way Im getting another 7.3 is with manual trans. Im not spending another 6k on a built trans. The only thing that worries me about the 7.3 is the guy said he hasn't really replaced anything in the past few years which means as soon as I buy it water pump goes, hpop leaks, ipr, cps, ball joints, injectors.
PSDlongbox's Avatar
PSDlongbox
Actually mine is bases on high miles on a ****ty automatic. If the 5.4 was a stick I would have gotten my vote.
Old Nov 13, 2013 | 06:20 PM
mdredneck's Avatar
mdredneck
I figured that may happen but I understand the benefits and pitfall of each truck , just trying to get opinions for my situation and what I need it for. Main concerns right now being maintenance cost, reliability and the occasional heavy tow.
Old Nov 13, 2013 | 06:22 PM
Bigpipes 35
Put a 6.0 cooler on the 4r100 and a temp gauge and I think the trans is just fine, I have 170,000 on mine and the only thing I use it for is to pull the fifth and has done it flawlessly for 5 years. Now put it behind a hopped up 7.3 and your right it probably wont live long...
Old Nov 13, 2013 | 06:25 PM
PSDlongbox's Avatar
PSDlongbox
Put a 6.0 cooler on the 4r100 and a temp gauge and I think the trans is just fine, I have 170,000 on mine and the only thing I use it for is to pull the fifth and has done it flawlessly for 5 years. Now put it behind pa hopped up 7.3 and your right it probably wont live long...
Depending on the build date, the mechanical diode is what I am worried about. It might only be 01 though.
Old Nov 13, 2013 | 06:28 PM
Bigpipes 35
Good point , def and issue to watch for..
Old Nov 13, 2013 | 06:29 PM
mdredneck's Avatar
mdredneck
How about the auto attached to the 5.4. Any known issues? Nearly impossible to find a 5spd 5.4.
Old Nov 13, 2013 | 06:33 PM
Bigpipes 35
Short of neglect no Issues and like I said add a 6.0 cooler and pull away..
Old Nov 13, 2013 | 06:43 PM
Ford Big Rig's Avatar
Ford Big Rig
7.3......wish I had mine back
Old Nov 13, 2013 | 06:56 PM
Irelands child's Avatar
Irelands child
I've had a truck with a 4.6. a 5.4 and a V10 and now a 6.7 diesel. Every one of them was a good one tho am still on a learning curve with the diesel. The gassers - absolutely zero problems, in fact they never had anything but routine maintenance. The gasses all pulled whatever travel trailer that I had at the time well though the V10 gasped a bit on long steep hills with 12K behind it. The diesel pulling the same trailer as the V10 does it so much easier. I guess what I'm saying is that you have to look at what your needs are now and what they will be in the forseeable future then go with what is the best to fill them. IMO, those miles on that 7.3 wont hurt the basic engine, but everything else on the truck will be suspect but will cost a bunch more to fix then the 5.4 plus with that gasser, even a decent corner garage or even you, if handy with a set of tools, can do most of those repairs.
We can give you food for thought, it's you that has to go with what's the best for your needs
