side window removel
Old Nov 12, 2013 | 03:35 PM
lilrobo's Avatar
lilrobo
side window removel
i been reading and do i have to remove the division bar just to remove the glass ,, looks like i could unhook it from regulator, then side it out ,,
Old Nov 12, 2013 | 06:44 PM
fbb1951's Avatar
fbb1951
It's much easier if the division bar is removed first. Then lift the glass out the top. Use masking tape to hold the window up to the door top while removing the division bar. Many strips of tape, on the glass over the door top and back down the other side of the glass.
Old Nov 12, 2013 | 07:51 PM
lilrobo's Avatar
lilrobo
I want to take it out to tint it, , i had them done in the summer and they started to peel up because he couldnt get the tint down below the anti rattle , so i was going to take it and do it my self ,, do the whole glass
Thanks
Old Nov 14, 2013 | 04:20 AM
Bluey Zedoff's Avatar
Bluey Zedoff
Guys, is the bottom of the glass glued into that rail? Is the only way of getting it out is to pull it out of that rail?
Old Nov 14, 2013 | 05:01 AM
lilrobo's Avatar
lilrobo
You can leave it in the rail, , just take the rail lose from the regulator, , i think the problem is when the glass is all the way down it dont clear the side channles, thats were you have to losen the division bar so it comes out between the 2 channels then it will come out the acc, panel at the bottom, ,,, thats what i am thinking.
Thanks
Old Nov 14, 2013 | 05:26 AM
Bluey Zedoff
Ah, that is the missing bit of the puzzle. That division bar. Makes a lot of sense now that you mention it. Thanks mate.
Peter
Old Nov 14, 2013 | 06:59 AM
ojh's Avatar
ojh
There are hairpin clips that secure the rail to the window regulator. The divider bar needs to be loosened on the bottom and you'll have to rotate the window and take it sideways out the top.
Old Nov 14, 2013 | 08:23 AM
lilrobo's Avatar
lilrobo
So can you loosen the bottom of the division bar and remove it from th bottom door? Or does it still need to go out the top?
Thanks
Old Nov 14, 2013 | 08:50 AM
jimcar-9's Avatar
jimcar-9
Check this youtube channel.
Step by step instructions
/ProjectF100
Old Nov 14, 2013 | 09:28 AM
fbb1951's Avatar
fbb1951
Try this link, then watch the rest of the series of videos.
Old Nov 14, 2013 | 09:29 AM
petemcl's Avatar
petemcl
Scott's Project F100 (1956) - YouTube
Jimmy - Can you fix this link?
Edit: Thank Jimmy. It works now.
Old Nov 14, 2013 | 11:48 AM
lilrobo's Avatar
lilrobo
fbb1951,, i have watched all the videos by that guy but he was changing the bushing in the wing glass thats why he went to all that ,, i just want to remove the glass
thanks
Old Nov 14, 2013 | 12:11 PM
ojh's Avatar
ojh
Thanks
I just did an F3, it had to go up. I've done F100 and don't remember exactly but i believe they go up too. It's a trick to be sure. You pull the hairpins from the arms on the regulator that attach to the bottom of the window track and once the hairpins are out you can move the arms out of the way to let the window slide to near the bottom - it'll probably snug up against the outside door skin - then you rotate the glass out of the division channel and send it up sideways.
This will be a good time to get some sounddeadener inside the door too and rebuild the tracks etc.
Word of caution, when you set the glass back into the window channel at the bottom it is directional. It has an offset to let the window go into the tracks and still connect to the regulator. before you knock the track off the bottom of the glass have a looksee at that offset and understand why it is there.
When reinstalling you slip the window back into its' door channells and slide it up and down to make sure it is free, you fill the bottom window channel with black silicon adhesive and set the glass down into it. Rotate the regulator arms back into place and slip the hairpins back in and run the door window back up top and let it sit overnight. It'll be good to go.
if you think i'm long winded ask how to do the vent window - thats when you hear the language!
Old Nov 14, 2013 | 03:30 PM
53OlderThanMe's Avatar
53OlderThanMe
I just took all my glass out for paint. I'm fairly certain the divider comes out the bottom on an F100. I don't see how it could come out the top since the mounting bracket is rivited on.
Old Nov 14, 2013 | 06:55 PM
fbb1951's Avatar
fbb1951
The divider comes out the bottom. The glass out the top.
