54 F100 build
Old 11-11-2013, 06:46 PM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
54 F100 build
I am replacing the engine and tranny with a 302 and c4...i have a strait axle and original steering. What headers will work ? I searched the threads but could not come up with the answer.
Thanks in advance.
Old 11-11-2013, 06:56 PM
bra$$monkey's Avatar
bra$$monkey
bra$$monkey is offline
I have a 351c with a c4
The standard cast iron manifolds work nicely.
That said - I think most shorty headers will fit into the same space as the iron ones.
Old 11-11-2013, 07:32 PM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks. I believe 5.0l and 302 shorty headers are one and the same...is that correct?
Old 11-11-2013, 07:34 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,449 Likes on 1,396 Posts
Unless you have the GT40P heads used on some Explorers, they are the same.
Old 11-12-2013, 09:06 AM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks, just purchased the motor mount x member, pads and trans supprt from mid fifty...Diane was very helpful but indicated that the trans pad was out of stock...i am planning to do the install this weekend...does anyone know what part number or manufacturer of that trans pad ? I d like to pick one up locally (vancouver) if I can.
Thanks again for your all your replies...
Old 11-12-2013, 10:41 AM
dmack91's Avatar
dmack91
dmack91 is offline
If you are talking about the mount that goes between the C4 and the crossmember, this is the one I used:
Anchor 2253 - Transmission Mount | O'Reilly Auto Parts
It was in stock at my local O'Reilly's and Napa. Any decent auto parts store should be able to get it for you.
Old 11-12-2013, 12:33 PM
yamagrant's Avatar
yamagrant
yamagrant is offline
Try your local Part Source. They should be less expensive than NAPA or Canadian Tire. Good Luck, Let us know how it goes, and get some pic's.
Old 11-12-2013, 09:55 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
I have a 351 and C6, and I'm using the stock manifolds that came with the 351. Remember when purchasing headers, that mustang headers won't work as the drivers side there is clearance issues with the gear box. Found out the hard way, I have a really nice pair of chrome small block ford headers that I can't use because of the gear box. Passenger side not a problem. You need to find some headers that drop similar to the stock between the 3rd and 4th cylinders.
Old 11-13-2013, 10:13 AM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks, thats the one !
Old 11-13-2013, 10:19 AM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks for your reply...are you saying regular mustang headers or the shorty ones wont work... Sorry if im being overly specific in my questions...
Thanks
Old 11-13-2013, 10:23 AM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks, found the anchor one at Lordco...
Old 11-13-2013, 10:45 AM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
SBF headers are the same unless you have speciality heads. It is the chassis that they are made for that is different. It is the width of the motor that will cause most issues, so because they don't fit in a 351 truck does not mean they won't fit a 302 truck. When I had my stock front suspension, early Mustang headers fit with no problems.
Old 11-13-2013, 01:04 PM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Thanks for the clarification. yes, I have stock front suspension...so sounds like I will be alright... will know for sure by this sunday
Cheers,
Old 11-14-2013, 08:58 PM
RhinoCat's Avatar
RhinoCat
RhinoCat is offline
Will begin engine transplant tomorow...thought we would take the entire front clip off for easier access ... Anyone have any thoughts / observations or suggestions on this procedure ?
Old 11-14-2013, 09:52 PM
Aarons54f100's Avatar
Aarons54f100
Aarons54f100 is offline
If you havent already I would remove the trans cover from the bottom of the cab floor. You may or may not have clearance.
Quick Reply: 54 F100 build
