No exhaust manifold gasket on right side leave it or fix it? - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Reload this Page >
Old 11-10-2013, 09:44 PM
scrobbie's Avatar
scrobbie
scrobbie is offline
scrobbie is starting off with a positive reputation.
Hey guys Scrobbie again I have my ole gray 88 which some of you know it runs pretty darn good thanks to your guys' help but im just wandering should i go ahead and put a exhaust manifold gasket on the right side? The reason the left side is on there, is because i had to replace the manifold. Due to a crack so should i Fix it let me Know. Thanks.
Old 11-10-2013, 09:47 PM
FX4-350
FX4-350 is offline
FX4-350 is starting off with a positive reputation.
They must come factory without the gaskets. I did head gaskets on my 351 and neither manifold had gaskets! Neither one leaked either but since I had the heads out, I put some gaskets on them.
Is yours leaking? I don't like to fix things unless they are broken. Unless it is leaking, you are bored with a few extra bucks to burn...go for it!
Old 11-10-2013, 09:51 PM
Evan_P's Avatar
Evan_P
Evan_P is online now
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
Ford never put gaskets on the manifolds. They used chassis grease in a think film which was baked into a varnish sealing them. If you manifold is not leaking there is no reason to put a gasket in there.
Old 11-11-2013, 09:40 AM
scrobbie's Avatar
scrobbie
scrobbie is offline
Thanks guys i did not realize that I dont think its leaking? but i do have the other one already here since I replaced the cracked manifold on the other side maybe ill just wait till spring if I do decide to put it on thanks again.
scrobbie
1997 - 2003 F150
02-13-2017 05:37 PM
scrobbie
1997 - 2003 F150
12-17-2016 09:33 AM
scrobbie
02-22-2016 03:26 PM
scrobbie
01-18-2014 06:12 PM
scrobbie
22
11-04-2013 03:53 PM
Quick Reply: No exhaust manifold gasket on right side leave it or fix it?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
