2011 f150 door ajar warning won't go away.
Old 11-10-2013, 12:53 PM
tractorfan's Avatar
tractorfan
tractorfan is offline
tractorfan is starting off with a positive reputation.
My f150 out of the blue says "driver door ajar" when I was on the highway today. The interior lights also came on. I opened the door several times, even slammed it. But still the warning will not go away. When I shut it off and get out, the chime and lights stay on until the accessories time out after 15 minutes. What do I do to fix this? Will be hard to drive at night with the interior lights on. Thanks.
Old 11-11-2013, 08:03 AM
DAFBFD58's Avatar
DAFBFD58
DAFBFD58 is offline
DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.DAFBFD58 has a great reputation on FTE.
Try some WD40 into the locking mechanism. It's the first thing I've tried that works
Old 11-11-2013, 03:39 PM
tractorfan's Avatar
tractorfan
That actually worked. Thanks.
Old 11-11-2013, 07:47 PM
69satelite
69satelite is offline
69satelite is starting off with a positive reputation.
Nice to see they have the same problem as my 2000 superduty had.
Old 11-13-2013, 06:22 PM
efx4's Avatar
efx4
efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
I learned the lubricant in the latch years ago when I had my 2000 F-150. The dealer service department told me over the phone to try that.
Old 11-16-2013, 02:49 PM
tractorfan's Avatar
tractorfan
Well it's back to acting up. I sprayed a full can of wd40 while working the door open and closed. But it will not help this time. Where is the sensor located? Do I need to replace the latch? Thanks.
Old 11-17-2013, 05:02 PM
efx4's Avatar
efx4
efx4 is offline
Did you do all door latches tractorfan?
Old 11-17-2013, 05:34 PM
tractorfan's Avatar
tractorfan
Just the driver door. It's funny because it has been acting up in above freezing temps. But tonight it has dipped below freezing, and now works fine. I'm stumped.
Old 11-17-2013, 06:09 PM
efx4's Avatar
efx4
efx4 is offline
Spray all door latches then open and close them a few times to work the lube into them.
Old 11-17-2013, 08:37 PM
meborder's Avatar
meborder
meborder is online now
meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.meborder has a spectacular reputation.
try white lithium grease.
attracts less dirt than WD, and has better creep properties.
that's what i use.
i've used PB blaster with good success as well, but it does attract more dirt than the lithium grease.
Old 01-02-2014, 06:46 PM
tractorfan's Avatar
tractorfan
Back to acting up again, this time it's 30 below outside. I can't even use my remote start. Do I need to replace the latch to correct this? Dealer says to keep spraying it. I'm running out of patience. I have had 3 other Fords and have never had a problem.
Old 01-02-2014, 10:32 PM
Trailblazen's Avatar
Trailblazen
Trailblazen is offline
Trailblazen is gaining momentum as a positive member of FTE.Trailblazen is gaining momentum as a positive member of FTE.
My 03 expedition has this issue. Never has really gone away. I just live with it.
Old 01-03-2014, 08:59 AM
tractorfan's Avatar
tractorfan
I could live with it. But it makes it so I can't use my remote start.
Old 01-03-2014, 09:42 AM
FordService's Avatar
FordService
FordService is offline
Official Ford Rep
FordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud ofFordService has much to be proud of
That sounds frustrating, tractorfan. Have you been back to your dealer so they can check this out? Let me know when they've had a chance to diagnose and I'll do what I can to help.
Crystal
Old 01-03-2014, 09:47 AM
ashleyroachclip
ashleyroachclip is offline
ashleyroachclip is starting off with a positive reputation.
I believe these switches are in the latch itself.
Have latch replaced.
Quick Reply: 2011 f150 door ajar warning won't go away.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
