Poking everybody with a stick - Air intakes.
#46
I just now removed the lid and checked the intake tube....it is clean as a whistle. So I guess it is working properly.
What I did find was that the electrical connector which goes on the filter minder is missing. I never noticed it there before. Is there supposed to be wires connected to the minder?? I looked everywhere and I didn't see an electrical connector hanging loose.
#47
You and I are both being misled. My friend with a stock 6.0L just so happened to stop by when I was reading your post and I grabbed a tape measure. The measurements in the spec are "absolute"... meaning all-inclusive with packaging and seals. The filter media (on both counts) is significantly smaller than the literature. The only way to really settle this is to dissect each filter and measure them up. I don't have a filter to tear apart, and my S&B will be here this week... so somebody else can do the deed if they're game.
Which amounts to a 30.35% difference in the amount of filter media.
Which is what makes me think the 6.0 filter is larger, and through my understanding of the powercore media, probably outperforms the AIS filter, in the absence of other data.
That conclusion was confirmed through my admittedly anecdotal observations of filterminder behavior followed by quantitative intake vaccuum magnehelic gauge readings on both intakes on the same engine (mine) back when Gene was around and the intake wars were raging.
But you don't have to take my word for it, I've been wrong before.
#48
dual 6637 intakes FTW.
OP, I'm going to join the crowd saying this isn't exactly rocket science. Get an intake that's tried and true and be happy. 6637, AFE Big boost, AFE stage 2 PG7. I've never used S&B, but some seem to like them too. Now all you have to do is decide on a price you want to pay and whether you want a cleanable filter or not. My new SD had an AFE stage 1 with the standard filter when I got it 3 weeks ago and I immediately pulled it off and put a 6637 on it because I simply don't care for cleanable filters..
Edit.... If anyone wants the AFE stage 1 to play around with let me know... I don't want to look at it on the shelf.
#49
#50
It looks like this.... http://afepower.com/catalog/51-10062/is.pdf
#51
#52
Up to f550 all years of the 6.0 used the equivalent the P603577. If he has that filter on smaller than a F650 it's not stock.
#53
I totally get that part, but he swears he did nothing to modify his truck, and I believe him (I know how the guy is about his truck).
The only thing I'm driving at is there's too much confusion in the matter of intakes, and I don't have the inclination to untangle that knot on my own. I made the effort recruit assistance to compile enough information to be helpful to others, but the thread spiraled and it chased off some viable prospects.
#54
#55
Having the specs was the easy part. Rots of ruck finding the flow data on the options. Hence... my effort... and consternation.
#56
Yeah, well I want to win powerball and retire to the Bahamas.
Anybody ever told you, you can't always have everything you want?
If that's really necessary, pay Volant to custom build a powercore filter to your specs. But don't expect it to come cheap, and don't expect it to fit in the space of the factory filter.
#57
I understand that as well. Now... if I have a list of filters with their performance graphs, I can sort out which spec(s) I can compromise on (and by how much) to achieve my ultimate goal. The ultimate goal? Over 99% filtration without Stinky trying to suck the filter through the tube - like a milkshake banana chunk through a straw.
What I have right now is many saying the 6637 is good up to 1000 HP and I should not overthink it. Once the 6637 is crossed off the list, I find myself in a spit storm. I'm pretty thick-skinned, so the dog piles and spit storms don't phase me like the truck does. I just wanted to give future shoppers a map through the jungle.
#58
Now I have been running the modded air box and K&N for about about 16,000 miles and I checked the intake tube and wheel for dirt 3 times and the first time at about 3,000 mile there was some dirt and oil I cleaned everything. Checked again about 6k & 12k and less and less dirt each time. I'll have it apart again here in a few weeks so I'll look at it then.
Bottom line is as long as I have this K&N I will NEVER clean it !! Because after about 10k of cleaning it start to work correctly. Is it an improvement over OEM yes but not by much.
So if you are stuck with a K&N drop in filter I say "Never clean it and check the air box lid for leaking."
Until then... OK, 6.0 and 6637 are awesome - I don't have enough flow data to compare. I'll have an S&B and share the AE data, if I see any differences between that and the AIS WOT runs. After I've run Stinky on the S&B and compared it with the AIS, I will have something concrete to stand on... because I wouldn't be counting on published data that I found in a PDF. Until then, all the shopper has is popular opinion and what information they can scrape together.
By the way since I am an old guy I for the life of me can't figure out what "FTW" would mean?? Sorry
Reps sent for offering up the filter for the cause
#59
That's the design parameters of the 6637 in our application. It's OEM designed application is a 170 hp neighborhood Cummins 5.9l 6BT power unit on Ingersoll-Rand highway pavers and air compressors. It's an effective filter if open element is your cup of tea, even though it's not designed to be an open element filter.
Look for more than that, and yeah it's going to seem like you're lost in the jungle, because there isn't more to it than that.
nosehair
10-30-2015 10:42 AM
