Rockauto Dorman SD UVCH gasket/harness review
Well, I just got done doing an injector swap, and installed the new SD valve cover gaskets along with them. So far, after initial start up, I can say that I'm pleased with them. I have to put some miles on them to be certain, but no problems yet. Figuring out the wiring was a bit of a headache, but once I figured out which wire was which for the truck harness and the new SD harness, it was simple.
From front to back, as the pigtail would be connected to the gasket, here's the order of the wires for the SD single connector: (passenger side)
1. #1 glow plug
2. #3 glow plug
3. #1 injector power
4. #3 injector power
5. Injector common ground (two wires splice into this from the truck harness)
6. #5 injector power
7. #7 injector power
8. #5 glow plug
9. #7 glow plug
Whereas, the truck harness with the two connectors is this (front to back):
1. #1 glow plug
2. #1 injector power
3. #1 and #3 injector ground
5. #3 glow plug
1. #5 glow plug
2. #5 injector power
3. #5 and #7 injector ground
4. #7 injector power
5. #7 glow plug
I soldered in the new pigtails that came with the gaskets, and used rubber heat shrink.
One piece of advice I can give to anyone else who wants to do this, is crimp the injector clips down before you install the gaskets. They went on my injectors really loosely, so I took a pliers and crimped them down to make them hold a little more securely.
So for now, I'm happy with the way they turned out. They were cheap ($50 a piece), the inside harness is integral to the gasket (no extra clip-on connection like the stock SD harnesses, so no need for the $.50 mod) and they came with a new pigtail. I'll keep everyone updated on them as I get more miles on my truck.
1. #1 glow plug
2. #3 glow plug
8. #5 glow plug
9. #7 glow plug
1. #1 glow plug
5. #3 glow plug
1. #5 glow plug
5. #7 glow plug
Yeah, that and there's only 2 SD pigtails instead of the 4 on an OBS. I'm glad I decided to replace them, too. The wires on the old pigtails were so soaked with oil and age that they were getting gooey. But cut them back about 4"-6" and the wires were nice and tight again.
What good is that? You would be splicing into a smaller wire(original harness) to feed a larger wire(new pigtails)
Good to know. Mine are still good at 160k and I have all the service records since the truck was new and no record of any GP repairs. But I am starring to throw CEL for one GP bank
The OEM (Ford) UVCH and pigtail is probably a superior product. The reason I say this is due to the design of the pins themselves. The ford pins are actually flat like this underline _ where the Dorman pins are round like this period . The flat pins have more surface area and can withstand a greater current capacity and heat cycles over time.
The only problem with OEM design is the additional inner harness connections and of course cost. I don't know if the Dorman 9 pin harness utilizes the flat or round pin style but I do know the Dorman 5 pin harnesses do use the round pin style, since recently I just replaced mine. This was simply due to availability and cost at the time.
