Turbo charging a 1994 f150 4.9 300
hey everyone, I know some of you have turbo charged these engines and wanted to know what I would need to run only 6 psi of boost for now. So far I have a Turbo that came off a 5.9 Cummings 12v. Would I need bigger injectors? head work? my truck is a 94 f150 with 402,293. miles on the odometer, with the 4.9 300. best gas engine ever put in. a f150
FORDSIX PERFORMANCE • View forum - Turbo, Supercharger, and Nitrous
You will find a bit of turbo info for the I6 there.
This makes War and Peace look like an afternoon read:
https://www.ford-trucks.com/forums/2...y-300-six.html
Easy to say, harder to do. On a truck with that many miles, imo not worth the time & $. Ymmv.
Holy smokes that's a lot of miles. I have a 96 4.9 turbo, I would say:
bigger injectors - yes.
head work - no.
The only easy way to get the fueling close on a speed density truck is with a rising rate FMU - and it won't get the same fuel economy with that sort of clunky mechanical solution.
I'd probably look into doing a rebuild with a slightly bigger cam and a roller rocker conversion, it would pull nearly as hard and you could probably get another 200,000 miles out of it.
head work - no.
There's a few guys in this thread that have made some really good progress with their turbo setups. May want to get in contact with them:
turbocharged 300 straight six?wtf? - FSB Forums
Ford-Trucker84537
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-22-2007 07:11 AM
jefxxo
12-13-2004 07:08 AM
