strong fuel smell in Cab
If that's where your leak is (or even if not) here's the info on the fuel pressure regulator parts:
Blue Spring
Upgraded fuel pressure regulator kit (with cover): Ford#3C3Z-9T517-AG IH #1843065C98
Fuel Pressure Regulator "Spring and Reseal Kit Only" (no cover, should be much cheaper, has gasket): Ford#6E7Z-9C165-B IH#1854267C94
Regulator cover gasket only: Ford#3C32-9C065-AA
It's a factory update (not a mod) that will increase fuel pressure to factory spec if it low. Many of the old springs are weak and fuel pressure is low which is hard on fuel injectors. An added benefit is the kit come with the gasket to fix a leaking regulator cover and it's inexpensive. Available at from your local Ford parts man or look online for bigger savings, many vendors stock them. Easy to install. There is a thread in the Tech folder with pictures and several youtube videos with details. You won't need the kit with the cover unless yours is cracked - which is pretty rare.
Blue Spring
I had a pretty strong diesel fuel smell both inside and outside of the cab. It would take a few minutes after starting up. It started just after having both fuel filters replaced at the dealer (that and other reasons have me NOT wanting to use the dealer service dept. any more). I looked and looked for a leak in the engine compartment, under the drivers door and anywhere between the fuel tank and the engine compartment - no luck. Finally I gave up and had a local garage look for the leak when the truck was in for another problem. I will give this guy credit. He did not give up (like me). He finally saw the engine mounted fuel filter cover "sweating" diesel. He replaced the cover and I have not smelled diesel for about a month now.
Hey everyone, I'm smelling fuel very strong at a standstill. Notice a lot of moisture around FPR and it's too dark to investigate until tomorrow. Question I have is I replaced my alternator last week and now this new problem. Is there a connection? Not very smart with engines, just wondering.
Dealer, although they are cheaper from autonation ford on fordparts.com, but you have to pay shipping. If it's the only thing you're buying, might be cheaper local dealer.
Blue Spring
Blue Spring
Sean
Dezl Newbie
27
01-17-2017 04:36 PM
99ExpyProblems
09-15-2013 10:34 PM
