'53 Ford Flatbed for 100 Year Anniversary Delivery Truck
53 F-250 rebuild
What engine does your truck have? Mine has the 215 ci I6 which I just recently got running. I am thinking of finding a more modern rear axle so that I can upgrade the rear drum brakes as well as get the rear drum operated emergency brake system. I will post some pictures of the truck this weekend as I have started re-assembling the front end.
Here's a couple temporary fixes you might consider:
1. Silver leaf the current emblems. Silver leaf is similar to gold leaf (both are usually done with inexpensive artificial silver or gold leaf rather than actual precious metal), it's actually not difficult to DIY. You can get the supplies, instructions at a good crafts or art supply store, or a sign supply online.
2. cover with chrome finish vinyl from a sign shop. They have wrapped entire vehicles with it. It stretches and conforms quite a lot with the careful use of a heat gun while applying light tension, is inexpensive, and stands up to weather for a year or more. The F250 would be best done by sticking a sheet to the face of the letters, and trimmed around the edges with a sharp hobby knife or scalpel, and then burnishing down the cut edges with an "orange stick" (if you don't know what this is ask any woman who manicures her nails). Give the boomerangs a sanding with a green nylon scrubbing pad from the grocery store to smooth it off so the pimples don't transfer thru as bad. To smooth it completely, fill the pits with a very thin coat of body putty, sanding off all on the surface before wrapping.Y ou can also get the vinyl in 6x24" strips at a hobby shop that caters to radio control airplane enthusiasts, where the peel and stick material is sold as "Monocoat" trim sheets. (you don't want the wider Monocoat covering film with the heat activated adhesive that comes on a roll.)
Pm me or email me at svassh@msn.com I have a pretty nice pair of boomerangs I will sell you if interested. Send me your email address and I will send photos.
I decided to go sans hood emblems except for the front on my 53 so these are just hanging in the garage. Would rather see them on somebody's truck than garage art.
Scott
Scott
Looks great. I have the same truck without the dual rear wheels. My side hood emblems aren't much better than yours. Maybe sand, fill and paint with chrome paint as a temporary measure until you find decent replacements. I hope to have mine on the road again by next spring.
Did you have any trouble finding replacement rear brake drums? What about the emergency brake pad (assuming it is the transmission mounted style on a 4-speed). I need both these items but have not found them.
http://earl.clubfte.com/
Great Information
farrellvdr have you looked at the earl's world thread? He has details on how you can do the parking brake linings yourself.
Bare-Metal® is Used for Detailing Model Cars, and Aircraft - Bare-Metal Foil Co.
These are great suggestions on the boomerangs..I am following up on a lead, but definitely feel like we can make some of these ideas work. Thanks everybody.
Update: We are finishing up the bed design. We have decided to go with white oak and I had a question for the wood runners that will sit on the frame: Does there need to be anything between the two?? Some kind of gasket material? Silicone?
Thanks!
Thanks!
Do realize that oak will turn black from exposure to UV (sunlight) in a short time. No surface film finish: urethane, shellac, lacquer will last very long due to moisture penetrating the open grain and lifting the film along with expansion and contraction of the wood will craze (crack) the film. Once that starts happening the wood will look terrible, and the only solution is to remove the film by tedious sanding or scraping and starting over. Also oak contains a large quantity of tannin an organic acid that when combined with moisture will be corrosive to steel (oak bark "tea" was used for centuries to tan leather). If you are planning to leave the truck parked outside, I would suggest using a close grained wood such as clear heart pine, maple, or best choice, clear fir and leave it finish free. It will weather to an attractive light silver grey that will be much in character with the age of the truck. There are some high priced exotics like ipe and resin impregnated wood sold for high end deck building along with synthetic (plastic resin) decking materials available that weather better.
#28
#29
There is a quite simple brake fix for this conversion where you no longer have the driveline brake. If interested, I can put up pictures of my conversion where I went to an auto transmission, lost the driveline brake and utilized the rear drum parking, emergency brakes.
#30
HTH. If, by chance you have the dash mounted E brake handle, something similar could easily be rigged using a cable. If you want to go with the vertical mount handle, someone on here will be able to accommodate you. Just ask. This is a 1949 F4 but there are enough similarities, the idea can be incorporated.
