my winter list
#212
#213
#215
Well after much searching I found the fitting I needed for the completion of the fuel system. these are 1/4" female inside pipe to 5/16 and 3/8 of the stock fuel lines. I could have done male pipe but then a union would have been needed. I am trying to keep possible leak points to a minimum.
here is the compression,npt to npt-pushloc assembled.
#221
#222
#224
Have to do...
Body bushings
Brake booster
Drive shaft rebuild
Front axle seals
Rebuild rad support,mount ic,paint
Build spyder and ic piping
Repair and paìnt hood
Bed repair paint.
So mostly its been apart three months and I haven't gitten near as mjuch as I should have.dang that list is much longer than I realized still.
And I'm trying to resurrect the bronco also...how depressing.
Body bushings
Brake booster
Drive shaft rebuild
Front axle seals
Bed repair paint.
#225
on
1 Post
Have to do...
Body bushings
Brake booster
Drive shaft rebuild
Front axle seals
Bed repair paint.
Body bushings
Brake booster
Drive shaft rebuild
Front axle seals
Bed repair paint.
