Detroit 6-71 in C or F600?
Young Fire Apparatus of the Buffalo area used 6V71s in the C series chassis in the '70s. But with your inline 6 I think if you moved the cab back a foot or so, you'd build a neat rat rod .
Allison MT 644 or 654 would be the trans to mate up. Or a 9 or 10 speed manual.
If so, in the absence of an auxiliary transmission, you'll likely need a final drive ratio of someplace around 3.00:1 to make it to 60 mph at 1500 RPM.
(with tires that are approx 40" dia.........and around 500 rear wheel RPM per mile)
You can calculate ratios below....
http://www.roadranger.com/ecm/groups.../ct_062746.swf
The Internationals used to put them part way back in the cab with a dog house. Most of those had bucket seats, and the shifter was almost at the back of the cab.
Nothing like a two stroke diesel screaming!
You could "bang gears" and sound like you were really doing something, only to see someone walking beside of you !
fordf350camper
04-03-2013 05:26 AM
