6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Positive for Glycol
Old Nov 1, 2013 | 05:09 PM
vancouver f250's Avatar
vancouver f250
Positive for Glycol
My 2008 F350 tested positive for glycol over a 2000 mile interval. After first test coolant system was pressure tested and was found to be sound. After first test shop suggested adding qt ATF drive 2000k, change the oil and filter and test again. 2nd test positive for glycol.
I was wondering what the most likely cause of antifreeze getting into the oil is?
Head gaskets, oil cooler, timing cover??? What else???
The truck has the DPF and Regeneration removed. 105,000 miles. Seems to run fine.
Can anyone recommend a diesel shop in the BC Lower Mainland or WA Pacific North West?
thanks
paul
Old Nov 1, 2013 | 05:57 PM
senix's Avatar
senix
Front cover cavitation comes to mind.
I take no puking at the degas bottle and no sweet smell at the tail pipes?
Old Nov 1, 2013 | 06:40 PM
vancouver f250
Positive for glycol
Thanks for the info - you going to have to bear with me - this is my first diesel.
Front cover cavitation ??
Puking at degas bottle??
I'll check for sweet smell at tail pipe
Thanks
paul
Old Nov 1, 2013 | 06:58 PM
senix's Avatar
senix
degas bottle is what a coolant overflow bottle is on a gas motor.
It is called a degas bottle on a diesel because it is part of the coolant system..not an overflow.
Behind the water pump is a cover..that cover.
Front Cover Cavitation - Oil And Water - Gallery - DTS
Old Nov 1, 2013 | 10:21 PM
vancouver f250
Positive fo glycol
OK then re the degas bottle don't see any movement in coolant when truck is running and up to temp.
The cavitation hole in the picture might explain why I had to add coolant every morning during my trip down south and back towing a TT. Anywhere from a quart to two quarts. Not sure from the picture where exactly this is but thinking it's not a job for an amateur to pull apart? Would this be fair assessment? Also thinking this job would be a lot cheaper than new head gaskets?
Thanks for your help on this much appreciated.
paul
Old Nov 2, 2013 | 06:01 AM
senix's Avatar
senix
Paul, certainly not a job for the novice. My suggestion would be a diagnostic of the cooling system to see where the leak is at.
Front cover is mere speculation at this point. It could be something else.
I would invest in a diagnostic at the service dept that has a certified diesel tech that works on the 6.4. That will cost you a bit but will be worth it.
Old Nov 2, 2013 | 11:23 AM
vancouver f250
Positive for glycol
Thanks again - it all boils down to $$$ - pisses me off as I had this truck checked out, specifically the engine at a Ford dealer before I bought it and now this. On the bright side I guess I'll have a better truck after all is said and done
paul
hydro man 17
Jul 20, 2015 09:51 AM
jhl3
Dec 15, 2014 12:36 PM
polarisman
Nov 1, 2007 03:17 PM
Tom D
17
Jan 26, 2007 06:37 PM
RedTaurus94
May 29, 2003 11:47 AM
