Winter & VWs can stay away November BS Thread
if you assume 12000 miles per year, that's 600 gallons (assuming 3.25/ gal)- so $1950/yr, vs 300 gal (assume $4/gal)- so $1200/yr. That's $750/yr.
How much does a swap cost? The goal would be to find a donor car that's been smashed for roughly $1500. But you should be able to sell off the parts you aren't using to make that near zero- It just takes time.
In the guy that did ranger swap did that. He figured these costs:
$260..intercooler and hoses, bends, MAP adapter
$70....fuel pressure regulator
$125...fuel system hoses, hardware, etc
$40....steel for mounting brackets
$150..aluminum driveshaft, shortened, balanced (also included was resurfacing of flywheel)
$350..timing belt kit
$150..PD150 intake with racepipe
$25....misc exhaust pipe
$100..wiring supplies (tape, connectors, solder)
$260..Beetle cooling system (condensor, radiator, fans)
$35....used 4L starter
$1565 total.
That doesn't include the adapter plate. Let's add a grand for that, and round up a bit...
If we make that $3000 even, that's a 4yr payback period- or less if you drive more miles. Plus, we all know a diesel ranger would be way more fun to drive.
I can't buy a truck with hips, but she never said I could'nt MAKE one!
1999-2010 Ford superduty dually pick up box
Good morning Jay.
Power came back on at 11:15 last night. Almost everyone on the street had no power too.
Good morning Troy. That's good news anyway.
Good morning Dave.
I like that idea....
These are the humble words of MisterCMK sent on the go...
Answer: no one.
who has made a 4 cyl, diesel 4x4 and shipped it to the US?
Ans: No one.
The easiest thing to do, is take a 4cyl diesel, mate it to the vehicle's manual transmission/drivetrain (via adapter plate). Integrate the electronics, and bam. done. (very similar to the ranger build)
So, I started searching what small trucks have a 4x4 4 door crew cab and a manual transmission available?
s-10/sonoma, tacoma, frontier.
Do I really want to drive a chevy? no...NO... NO...
So the frontier... can't get gearing low enough to keep the rpms down. MPGs won't be produced here
and to the tacoma. the taco. I don't like them, but better than a chebby. crew cab long box exists- but not with the manual trans. manual trans is in the reg cabs mostly. But, they are available.
I figure it would be about a $3500+tacoma project. Ideally find one with a blown trans/motor...
#28
I have heard Mike called many things but magic..........
TERRIBLE CREDIT BUT NEED A CAR? CALL MAGIC MIKE
#29
