The oldest had basketball clinic at Norwich university this afternoon. Then came home and took the stuff out of the garden and cleaned up the garage some.
Originally Posted by 97HDF250
Hahaha. I couldn't believe they put a screw in it. But now my gauge goes almost all the way to Hot before coming back down
Guess I missed something. Someone put a screw into the thermostat to keep it open?
all I did was watch a race and watch the wind blow everything all of the place.
another thing too look for is air in the system. unless its 195* thermostat. then it'll run warmer than normal. sometime the ECM and sensors are set at certain temp otherwise the sensors won't work right.
Possibly the radiator may be partially plugged not allowing all the radiator to be used. Which may have been the reason for them to lock the thermostat open
