Explorer 8.8 rear questions
Thanks for the pics, I did the same thing on mockup with the flipped rear shackles, should work out nicely.
Original plan was to use a chevy rear with adapters to go to the Ford wheels I am using. I thought that going to the explorer rear would allow me to not have to use adapters but with the late model Ford wheels I am using I would still need 2" spacers on each side.
So since I still need spacers I will go with the original plan of the chevy rear and get spacer/adapters to the ford wheels I want to use. This way all 4 corners are GM pattern with adapters so if I change wheels to a standard offset GM pattern I can just remove the adapters.
I used Dakota springs with the Dakota hangers, 1997 If I recall correctly.
And 2001 8.8 explorer axle 3.73:1 Limited slip. I dropped the front hangers low and reversed the rear shackles putting them upside down. I added add a leafs to correct the low ride. typing fast and sloppy sorry so vague.
not done yet, but this picture shows a little. I can take more next weekend.
What kind of gas tank do you have installed there? the inlet is in front? are you putting a gas cap in the fender?
THanks!~
Those are 90 D-50 spring hangers and shackles. Putting the springs above the axle will drop the rear a minimum of 4-5 inches. Here's a picture from the side so you can get an idea of how low it might be. I didn't want my truck too low since I have to traverse some less than ideal roads here in New Hampshire but this was just low enough...
Got any thoughts????
Pearlwhite94
01-09-2015 03:53 PM
coogie
11-24-2012 01:14 AM
Mike Rettinger
04-07-2012 07:11 AM
chris_p04
09-24-2003 08:43 AM
