LOTS of left over 80-97 F series and Bronco parts
#46
Category: Exterior - Body Parts
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, CL, TL & Vigor
Item Condition: WA
Shipping Information: Item can be shipped
Engine: Part suitable for gas truck, Part suitable for diesel truck
#47
BruteFord, I saw in your original posting you had to wiring harnes for a 1988. Do you still have these? I have a 1987 Ford Bronco, auto/302 fuel injected, my underhood wiring is shot. It is giving me all kinds of problems. If you have a mostly complete harness I would be interested in buying it. Thanks
#48
I really dont know much about the 6cyl ford trucks. I dont know what the diffence between the two of them are. I dont want to get into something that is going to be more work than what I already have. I really would like to find a good plug and play harness or at least a matching one. Do you know what years I can use? Thanks
#50
I'm doing this with one of my trucks now, the headlight switch caught fire with the PO taking out much of the left side of the dash. I have two other dash harnesses from similar trucks but there's so many small variations that I can't just use the complete harness from either. So I'm removing all the burnt parts from it and replacing them with good parts taken from the other harnesses.
#51
I am purchasing a 86 f150 with 5.0 and C6 and I am in need of under the hood wiring. PO had some rats/ squirrels or whatever get under the hood. Also looking for fuel tank switch on the dash as well as the mechanical/electrical parts.
#52
#53
I've got a 1986 f250 2wd with a 4.9l 300 under the hood and I've been looking for axle pivot drop brackets for a 2 or 4 inch lift or a set of dual exhaust manifolds from a 90s ford or headers
#58
Kick panels are, I remember cause I just took them out, I'll have to get back to you on the pillar covers. I think the drivers side pillar cover has a couple screw holes from a previous owner mounting something there. Just those 4 pieces?
I'll send you a PM after I take another look this weekend.
