1953 F350 Tow Truck
#31
The 8-17.5" bias ply or 8R17.5" radial tires will be around 32" tall while your stock 7.50 x 17s are 34". Whether that difference lets you go to the smaller half ton wheel opening is the question. These 17.5" tires will be close in diameter to a 7.50 x 16" tire. That would be a pretty tall tire to mount on a normal half ton. Might be that a low profile metric sized 17.5" tire would let you come up with a shorter combination that would fit the smaller wheel opening. Stu
#32
Thank you Stu. I was going by the chart posted by NumberDummy it says a 56 with 15" 16" and 17.5" uses B6C 16005-A https://www.ford-trucks.com/forums/1...l#post13695218
Thank you
Kevin
Thank you
Kevin
#33
Thank you
Kevin
Thank you
Kevin
https://www.universaltire.com/truck-...transport.html
Normally a radial tire will be slightly shorter than a bias ply. So an 8R17.5" radial might be nearer to 31". So, circling back to the comment in my above posting, it may be that a metric sized 17.5" tire may be shorter yet. I suggest checking with a tire dealer locally to see what is available. Stu
#37
No Stu. but if you have seen all the pictures it does look like it does. but from what I have been told 53 was the first year with a set back front axle. now the left side is set back which you can see in the picture in this post. now on the right side some one replaced the front leaf spring with the right length but the centre spring bolt is in the wrong location so it puts the wheel in the centre of the wheel opening. the fenders on the truck are a little bit ruff for me.
Kevin
Kevin
#39
Kevin
Kevin
df85732
820
06-27-2022 01:06 PM
Will Gilbert
04-06-2016 08:08 AM
shorty85
12-16-2006 04:46 PM
