77 300 6cyl fan removal
I have a 77 f100 Custom with a 300 inline 6cyl. My question is on the fan removal. It doesn't have a fan clutch. There are a total of 5 bolts holding the fan blade on. The center bolt, is it left handed threads? I was able to to remove the 4 surrounding bolts but the center bolt didn't seem to want to budge. I'm thinking it is reversed threaded.
Thx for the help.
Thx for the help.
Agreed, the center is simply an alignment pilot for the fan. Once you removed the 4 actual fan bolts, the fan and spacer SHOULD come right off, however, it is not uncommon for corrosion to cause the fan to stick to the pilot, and /or the spacer to stick to the water pumps pilot. usually a couple of taps with a hammer will pop it off.
Agreed, the center is simply an alignment pilot for the fan. Once you removed the 4 actual fan bolts, the fan and spacer SHOULD come right off, however, it is not uncommon for corrosion to cause the fan to stick to the pilot, and /or the dacer to stick to the water pumps pilot. usually a couple of taps with a hammer will pop it off.
Ok, Cool... Thx for the info. I'll try that.
Bill Lamb
27
09-10-2007 08:14 PM
