79-80 crossover
-chris
2FT E F26 Y X F C A91132
2FT = WORLD MFR. IDENTIFIER = Ford Motor Company of Canada, Ltd., Truck, Complete Vehicle
E = BRAKES/GVWR CODE = CLASS E = 6,001-7,000 LBS.
F26 = SERIES CODE = F250 4WD PICKUP
Y= ENGINE CODE = 4.9L/300 cid 6-CYL GASOLINE-POWERED, FEEDBACK CARB OR EFI
X = CHECK DIGIT (IGNORE, FOR FOMOCO USE ONLY)
F = MODEL YEAR CODE = 1985
C = ASSEMBLY PLANT CODE = ONTARIO TRUCK
A91132 = NUMERICAL SEQUENCE OF ASSEMBLY
EXTERIOR PAINT COLORS = 2E = LIGHT CANYON RED, USED 1984/87
DSO 12 = LOCATION OF ORIGINAL-PURCHASING DEALER = BUFFALO
F0393 = 393 lbs. of accessory equipment (e.g. plow) can be placed on the front axle without requiring recertification
T0656 = 656 lbs. total weight of accessory equipment (front + back) w/o requiring recertification
WB 133 = 133" WHEELBASE
TYPE-GVW F261 = GVWR... IN 1983/87 THIS IS: F250 4WD PICKUP, 6,600 LB. GVWR
BODY BB4 =
B = TRIM COLOR = BLUE
4 = BACK OF CAB EQUIPMENT = M = REGULAR CAB W/STYLESIDE PICKUP BOX (TYPE 99)
AXLE 23 = IN 1983 THIS IS: 3.54:1; 5,300 LB. CAPACITY; NON-LOCKING
TAPE = OPTIONAL TAPE STRIPES TYPE
SPRING 5 6 =
6 = REAR SPRING IDENTIFIER - F1TZ-5560-E Replaces E0TZ-5560-B used earlier REPLACEMENT PART NUMBER
Source: FoMoCo 1980/89 Light Truck Master Parts Catalog (available on CD from hipoparts.com)
Same deal with the rear axle, but I've been over that. Wrong code again, the rear axle is a Dana 60 limited slip with 3.73 gears. The front is a 3.73 geared Dana 44 TTB. Both original equipment.
Otherwise everything seems to match up. The 4.9 had a feedback carb, and i have pictures of it with the tape stripe. Surprised it don't list anything about the bed cap it came with or the running boards, or the grab handles outside the cab.
It hasn't had the 6 cylinder in it for going on 20+ years now, its on its 2nd going on 3rd V8.
As far as the boards and cap etc it came that way when the original owner bought it. He bought brand new but saw very low mileage as he died about a year after he bought it. It was my grandpas boss's brother, so my dad bought it in '87. The cap was already sold at that point. I've got the original bill of sale laying around somewhere.
BD is, in fact, a red all-vinyl full-width bench seat with red trim.
All I can tell you is what the book says...
I'm also trying to figure out how that got in there as factory equipment. I figured you guys would be all over that but I guess not.
Anyways, I appreciate what you've done, so thanks!!
Swapping truck axles isn't real hard for a shop with the right equipment. The label shows what it had when it left the factory, nothing more.
The thing with the axle situation is my father bought it just under 2 years old and he's never changed the axle or anything in it. I find it hard to believe an axle grenaded under 2 years old, especially a Dana at that, and needed to be replaced. There's simply no need. I understand axle swaps are easy, I've done a few myself. That's why I figured you would all be all over it since I believe it to be undocumented. The only other thing I can think of is the original owner which we knew wanted a posi type rear and changed it but then again it nothing else was changed. Even then I have my doubts.
I'm dropping the situation anyways. Thanks for the help though. Appreciate it.
The tag on the axle has the last word... well, it *should* have, but those get removed or changed by people pretty easily so are not entirely reliable, either.
For the tag to be wrong, that would imply that:
1) The price sticker would also probably have to have it wrong
2) The Build Sheet (probably between the foam & springs underneath the front seat, sometimes between the carpet & floor) would also likely be wrong
The Build Sheets followed the vehicles down the assembly lines as they were built, and screw-ups have been known to happen (one front drum brake, one disc brake on the other side, for example (not talking trucks here, some car another member told us about)). But there aren't many of 'em.
If you still have the axle's original tag, that might tell something; but, the most definitive way is to find out is to count the revolutions of the driveshaft as you turn the wheels around one full turn, and it seems you've done that.
I don't know anything about a price sticker, though I think, and I really stress I think, I have the original bill of sale. I may be wrong however but I'm not sure that would have any say.
I've never seen the build sheet but I don't believe it's survived the way my cab looks. The floor is literally gone and the seat is in rough shape, so unless it's been moved to somewhere safe like in the glove box or in the little storage box between the steering wheel and radio, then it's probably gone.
A build sheet screw up would be interesting. I know there isn't many of them, but that would be kind of cool. Is there any way to request an official build sheet by email? I would probably be corrected but even still.
I have indeed turned the wheel, and I have had the cover off the back at one point. That's how I got the 3.73 gears, and my father also told me that it "came that way". He said the front had them too, but when questioned again he seemed to have forgotten and he said they were probably the same as the rear. He's like that sometimes. I would like to think he's correct simply for the fact of how many times he's rebuilt the front axle (yearly in fact) for plow season.
