Help Me Plz!
Old Jun 20, 2003 | 04:26 PM
Effie3's Avatar
Effie3
Exclamation Help Me Plz!
I have a 460 in my 53' F-100, I'm pulling it and completly rebuilding it. I need to know what works the best with the 460's so I can smoke all these punks talking trash on fords PLEASE YOU GUYS! I need help from whoever knows what works the best with a 460. THANKS!
Old Jun 20, 2003 | 06:04 PM
georgedavila's Avatar
georgedavila
Help Me Plz!
Prepare a plan for the hp/tq range you're after which takes streetability and budget into consideration.
Old Jun 20, 2003 | 09:30 PM
Effie3's Avatar
Effie3
Help Me Plz!
I'm working with about $2,000, and I want to get as much hp as possible while still being street legal. Thanks
Old Jun 21, 2003 | 08:05 AM
georgedavila
Help Me Plz!
In most states your only legal issue regarding the engine in a '53 should be the level of exhaust noise.
Using $2k as a budget goal, I'd get the engine out, torn down, measure the bores, crank throws and mains to determine what it needs for the shortblock rebuild. If it needs boring, new pistons/rings, crank turned, decked new bearings or just a hone, new rings and bearings will be the first step in determining what portion of your budget will remain for modifications.
Old Jun 21, 2003 | 03:30 PM
Effie3's Avatar
Effie3
Help Me Plz!
Hmm.. will do. But, How would I get the most traction, E/T's maybe?
Old Jun 21, 2003 | 07:02 PM
airharley's Avatar
airharley
Help Me Plz!
As for traction you have a few options available. You can use a Detroit Locker, limited slip, or a Track-loc 3rd member. Gearing will be a factor also. The higher the ratio the faster your wheels will spin. Look at doing a ladder bar system but with the budget you have this will be a little out of your reach at the time.
Old Jun 21, 2003 | 07:04 PM
Effie3's Avatar
Effie3
Help Me Plz!
ok thanks
WWB F250
Jul 5, 2006 08:00 AM
weldingfreak
Dec 21, 2004 12:57 PM
75pup
Feb 26, 2004 10:42 AM
nothingbutford
May 26, 2002 06:23 PM
