Cold air intakes?
Banks makes a pretty good set up, I'm looking into getting their full set up.. Look on SummitRacing.Com or Jegs.Com
Banks Ford 7.5L Stinger Systems 49252 - Free Shipping on Orders Over $99 at Summit Racing
jarryd is correct. Unless the intake is drawing in outside air thru a scoop or something of the sort its worthless. All it is doing is sucking in hot air from the engine bay.. The stock air box should have snorkel that goes up by the grille or hood opening, my 96' 5.0 did and that is just as good.. Granted now I have removed the air box and got some custom piping and have my filter turned up to where it draws in air thru my hood scoop which is "cold air" and it did make some noticeable improvements.. But save your money and get gears (4.10) or a cam... hell get some long tube headers and full exhaust.
Thats a lot of money for a muffler, tailpipe, and a fancy aluminum airbox cover.
"cold air intake"...more like hot air intake, the stock set up is more then enough, if you truly want "cold air" your looking at putting in a snorkle similar to what some jeeps or off road vehicles (hummers in the military) have. best upgrade I would suggest is (if you have the 5.0/5.8 snorkle) is the intake that is off the I6 (i think) that puts the intake right behind the drivers side head lamp where the air is clean and cooler then from the engine, also less restricted by the tiny gap between the hood...
460GasMeister
05-06-2014 10:43 PM
Canadianpowerstroke
12-08-2013 05:25 PM
Warrior449
20
05-14-2012 11:27 AM
