FABRICATION!! We want to see what you've built.
#167
#168
#169
#171
In the extension: (L-R) emergency brake release; AC/heat outlet; headlight switch; column drop; ignition switch; wiper switch; 2 H/AC vents; 2 12V outlets; H/AC vent.
In console: (T-B) 2 12V outlets; heat/AC controls; head unit; pop-out cd holders; switch bank; 2 cup holders.
as well as my ongoing rust repair post:
https://www.ford-trucks.com/forums/1...g-try-2-a.html
#172
I had posted it and pix in my gallery, but here is the test fitting:
Is it the flash of the camera or is that center console built with galvanized hvac metal and EMT conduit?
#173
#174
#175
Yes, the T56 shifter is back there, but not nearly as far back as on Gary's 5650 (Ford's T5 variant with remote shifter for the Mustang) where his shifter pivot is a couple inches behind the tailshaft. I'm going to modify a Hurst short throw shifter kit for him to move the shifter about 10" forward. Here's a wider angle picture that shows the relationship between the console and the shifter with the base for the shifter boot.
#176
The shifter is about even with the front of the seats. Since it's a panel I wanted to leave walk space access to the back between the seats, so I stopped the console short of the shifter.
Are two wire conduits I see in your doors are they Part # 1738 braided from Mid Fifties? If so why two? How is the flex bend when door is all the way open? I notice a 2 " hole approx in line with each conduit, are they for the conection of the conduit in the door jamb? I bought a couple sets of those and was able to make one work for my rear panel door but when I was looking at the side doors I was thinking the bend was a little to radical,, but your picture looks like I am going to rethink my thoughts.
#177
Ax
#178
Mine are no name I got off ebay before MF offered them. They work just fine, but the center is small (has teflon? inner liner) so I was afraid there would not be enough room for all my wires (remote door locks/alarm, power windows, possible speakers) so I decided to put in two. (I don't think the unlined spring type would work as well). The holes are there because there is a hinge/post brace inside the door the wires needed to pass thru, so I used those holes to access the brace to drill it for the wires. I will screw plates over the holes before installing the door panels. I will also cut out and cover the raised areas around the original door handles and window crank so the panels will sit flat.
Mid-Fifties has a nut on each end so access to both side is required to instal, so cutting the inner panel will be required. Do you have the brand name of those you used? I was als thinking about using the door strike pins that Painless sells.
#179
Thanx Ax, kind of figured that was also what you were doing with the 2" hole.
I think what you are referring to is the no wire contacts. Since mine control the locks, I didn't want to take a chance a weak contact would prevent the locks from operating, plus they are expensive and not very attractive. If I was doing it again I might look at some of the OEM rubber ducts in the U-pull yard.
#180
Received 4,130 Likes
on
New Door Jam Wiring Loom Conduit Kit Teflon Lined Stainless Steel Braided Hose | eBay
These are the type of door looms I used Gerry, the ones I bought were from electralife or something like that, they are much better because they don't bind up and the stainless braiding don't wear.
